PCB
In one of the videos, Jamie says that the QEG is a high voltage device, not a low voltage one as they had first thougth. Interesting statement since he supposedly had already built his own prototype. He then goes on to say that if they can get the output voltage up to 2KV and the current to 5 amps they will have their 10KW generator. Right from the beginning these guys have assumed that the output power is simply volts times amps. Jamie can not be an engineer. No engineer would do this for an AC system, but these guys do. Does anybody present at these gatherings even raise their hand and mention rms or power factor.  I for one have not heard these terms in any of their videos or seen them mentioned in blog posts of others reporting back to the masses.
MileHigh did a great job of explaining things. I'd like to see a concise posting formulated and placed on the http://be-do.com/index.php/en/forum. If you have posting privileges it will appear immediately. This posting should be screen captured and posted back here. If it later is removed this would indicated that they are knowingly scamming folks.
I would suggest that perhaps MileHigh should take the lead on preparing a concise power cal analysis. I have posting privileges and would be pleased to post it in response to Dave Starbuck Sunday, May 18, 2014 posting.
SchubertReijiMaigo
WTF ? 35000 $ without counting indiegogo 18000 $.
QuoteBad news.  HopeGirl is using the alleged "over unity" clip that is actually under unity to solicit funds.  It's simply unethical behaviour.
Let's call a cat a cat: it's a scam.  :P
I'm more worried that kind of things will do a lot af damage in the OU community where I believe that are honest researcher out there...
In fact when I see some new-age hippy things like "HopeGirl", "One People Community", "Our mother Gaia", "Love people",
->put every new age terminology here<- , where demonstration are performed in a village in the middle of nowhere it tend to raise in my head some big red flag.  ;D
Hell, doing science is not the same things as preaching in some new age group...
PCB
This was posted yesterday here by Hope More. A press release of sorts probably not written my hope moor herself, but clearly meant to keep the money machine going.
http://www.gofundme.com/HopeGirlFixtheworldQEG
Updated posted by Hope Moore 1 day ago
Important QEG update: The word from Aouchtam is OVERUNITY!!! Made possible by YOU - The People!Hope and Val left Morocco last Monday and are in the UK preparing for the next QEG build. We tried to remain in Morocco with Jamie until the goals of overunity and self-running were reached, but could not. More details coming soon (see last update for list) but we wanted to get you the good news!In this update, please open the link and watch the video of the all-important overunity step being reached. Blessings to all who helped make this possible - together we are creating the world we want to live in!
They screen says they have raise more than $34,000 and there goal is to raise an additional $20K, and they will likely do it based on this posting. "Dave" who reported the output power at 2.6 KW and later updated his number to 3 KW after supposedly talking to Jamie. Why did Jamie not correct Dave and explain that this number represented the instantaneous power and not the average power. Hope girl etal is clearly having a great time in the limelight jaunting around the globe. But its a total sham.
Here's what a real resistive load looks like. Note that for under a hundred pounds Sterling one may purchase a genuine 2000 Watt resistive load of 50 ohms resistance.
https://www.inverterdrive.com/group/Dynamic-Brake-Resistors/ECOMSA-Dynamic-Braking-Resistor-50-Ohms-2000-Watt/
He just needs to push a bit under six and a half amps through that load to dissipate 2 kW. And it will only take a little over 300 volts to do it.
"But our output voltage is in the multi kV range!" Sure... and what happens when you connect an unregulated voltage source to a low impedance load?
MarkE
Quote from: TinselKoala on May 20, 2014, 12:02:36 PM
They could always start by purchasing a load that matches the open circuit voltage by the expected current.  Even better that if by adding suitable switches or wiring options that they could change the load as needed.  For instance they could get a suitable fixed step down transformer and variac combination.  Or they could go really simple with:  2000V / 5A = 400 Ohms and buy eight of those 50 Ohm resistors, and stack them in series.
