0 Members and 52 Guests are viewing this topic.
On a more serious note, there is a poster on Be-Do that is in the "QEG zone."
QuoteAligator31 posted a brilliant design idea using Russian 4x12x62mm ferrite flat bars. I have just finished doing the calculations on that design in a 6 page PDF, which I will post soon.
I show how doubling up on the core stack 6 deep instead of 3 deep to double the cross sectional core area, provides a 1500W device costing less than $400 to build. Further placing a second core stack below the PCB (as just one idea) you have a 3000W device for just a few dollars more.
With only 364 turns on primary coils using 16# wire and 24 turns on o/p gets you a 1.5kW mini-QEG. The calculations show where the problem dissipation areas are, it appears a 27:1 over unity factor is a possibility. Primary voltage is only 200V peak on the primary.
QuoteNow when a Lenz law reverse response hits the air-core transformer (the only one that actually exists as a transformer in any real sense driven by a resonance excitation), the effect has nowhere to go in context of the air-core - there aren't any corresponding "air coils", so the effect cascades down upon the coils of the metal-core, and voila - it encounters that dead short, and is slammed to zero excess power. All that happens is a largish reflected load current dissipates plenty of heat in the primary wire, so thick wire is good, but beyond that a BIG FAT ZERO POWER due to the zero volts across that dead short. A 10,000W o/p load is balanced by a 0W power budget in the primary, which is just unheard in the electrical profession. I am an electrical engineer, but in all my born days never would I have ever suspected something like this. All there is in the primary is a few watts in the wire due to the size of the reflected load current. Understanding how that is even possible is the key to appreciating how over unity works
QuoteActually I see a new inverter topology (I have already designed an initial prototype), which incorporates an over unity device built tight into its o/p power section, so the the MOSFETs of the H-Bridge are switching at very low power. The QEG belongs at the input of the inverter, but it is also true an over unity device needs to be built into the inverter itself, to dramatically reduce cost, and heat, power complexity of the H-bridge switching elements.
And so on.  If there are QEG builders reading, especially newbies, the user "vgray35" might be wowing you with his technical knowledge and he claims he is a retired engineer.  He is sounding very technical and some things he says make sense but he is using a really contorted way of expressing himself which is a red flag.  He is also tripping into the electronics fantasy zone, and that makes no sense.  So, in all honesty, don't give any credence to his multiple claims of over unity circuits.
ariovaldo
Don't shoot the messenger. I just received this link and I never saw that before.
http://www.wardenclyffe.es/inicio.html
Cheers
Ariovaldo
PIH123
Quote from: ariovaldo on May 27, 2014, 10:33:35 PM
Cheers
Ariovaldo
Even Sterling thinks this one is a scam. That has to tell you something.
http://peswiki.com/index.php/Free_Energy_Blog:2014:05:27#Wardenclyffe.es_Most_Likely_a_Scam_--_Possible_Decoy
wardenclyffe have pictures on their website with their own logo on machines, claming them as theirs,  which are regular generators built by
http://www.chin-power.cn/factory.html
ariovaldo
Quote from: PIH123 on May 27, 2014, 10:54:59 PM
wardenclyffe have pictures on their website with their own logo on machines which are regular generators built by
Yes, I know.....
Thanks
