Angelic
I too had the same thought on the other resonant points. The second one (I think) showed to be very bright.
Farmhand
Quote from: Khwartz on May 30, 2014, 07:15:51 PM
Are you just a troll to state something without demonstrating it?!
I was until now VERY DOUBTFUL about the whole thing, but see this vid and studying the so clear report which fits exactly to the vid, I bet these guys are genuine.
My main arguments are:
1. In this last doc and vid, all is perfectly clear;
2. What is actually claimed is what is indeed demonstrated: not Real Power overunity but VARs overunity.
If indeed they can transform this VARs Power in Real Power, we all win (except off course the main energetical industry and their trolls, off course ;) ).
Well, could be I am wrong, but except the French teems on the Richard Vialle's Autogenerator, I have never seen since I follow this quest of Free Energy, so clear and factual report with so precise usable measurements.
Regards to any honest to this Quest, and Very Well Done for this So Very Clear Vid and professional report like I would have always dreamed to see hete around.
Obviously some people just don't get it.
All the activity (oscillating power) in the Tank is input from the power supply. Fact or fiction ?
If not where does it come from ? I'm certain that the energy in the tank can be demonstrated to be "from the supply", by careful measurement.
Attaining a large amount of oscillating power in a resonant tank is the easy part thousands of people do it every day. Seeing the "QEG" showing a larger oscillating power than the input power is not even interesting or out of the ordinary.
Many have claimed that the greater oscillating power than input power is OU but none have shown any evidence or argument that is sensible.
Any half descent resonant tank can show a great amount of oscillating power. That is not output. Before energy can go out, it must go in as we cannot make energy.
There is no mechanism I can see for any external energy to enter the device, then be output to an intended load.
I myself have achieved hundreds of watts activity with under 10 watts input. This is nothing more than accumulated energy from the supply.
Angelic
At this point I just want to see their attempt to self loop. And wouldn't all agree that this last post is the most detail that has been provided to-date on their set-up and the measuring procedures used. I am not saying that the have achieved OU yet. I am only saying that this is the most information that has been provided so far.
pmgr
Quote from: Angelic on May 30, 2014, 05:03:24 PM
More from Hope.http://hopegirl2012.wordpress.com/2014/05/30/major-breakthrough-in-free-energy-overunity-demonstrated-in-the-qeg/
This report is good in the sense that it explains what the setup is exactly and what has been measured and how.
I have read the report in detail and based on the reported measurements (not the reported interpretations), there is no overunity. The analytical analysis of the test results is lacking.
Here is my feedback on the various new experiments they did:
Experiment 2
6x100W bulb load is in the secondary circuit in series with the coil. Resistance of a single bulb is 576ohms (100W at 240V). Or total load is 6x 576 = 3456 ohms (when hot). Their resistance number of 251.5 ohms appears to be the measured cold resistance of one bulb (or 6 bulbs in series; this is not clearly stated).
No efficiency is mentioned for the secondary circuit but it is clearly under unity based on the traces (around 30% max).
Then the power is analyzed in the primary circuit. In this case there is no load in the primary circuit, so of course what is measured is not real power. What seems not to be understood by them is that measuring reactive power in the primary can not be simply assumed as transferable into real power or into extractable power. In fact the energy oscillating in the primary circuit is energy stored in the coils and capacitor; the energy is transferred from the coils to the capacitor, then back from the capacitor to the coils, etc. Some energy is dissipated in the coil's resistance. What is actually measured is the rate (power = energy / second) of energy transfer between the coil and capacitor. They mention a number of 22,800 VAR, or 22,800 Joules going back and forth every second between coil and capacitor. This is certainly possible, but should not be used to claim overunity. With a 100% efficient motor drawing 607W, it would only take 37.5 seconds for the motor to build up this energy into the primary circuit. The question remains, how much real power can one draw from the primary without destroying the resonance and whether this number is more or less than the 607W that the motor puts in. From all experiments done to date, this number has always been less than what the motor consumes.
Experiment 3
This experiment is similar to Experiment 2 except that the load appears in the primary coils.
For the secondary coils, the same logic applies as what is explained above for the primary coils. What is measured is an energy transfer rate between coil and capacitor, not extractable power. In order to determine extractable power, a load has to be placed into the secondary circuit.
For the primary coils, it appears the voltage is measured over the load and capacitor together (or over the coil), so the current shape is very non-sinusoidal and there is no point discussing RMS power in this case. The voltage should instead have been measured over the bulbs to get an estimate of what the real efficiency might have been in this configuration. Here again no over unity is shown. Just some numbers that show the energy transfer rate of energy accumulated in the circuit between coil and capacitor.
Despite the fact that no overunity was shown, I think it is good though for everyone to see the full measurement report and raw data (despite the fact that some of the conclusions drawn in the report are incorrect). People should be able to draw their own conclusions based on the raw data.
PmgR, Ph.D. EE
Help stop the persecution of Falun Dafa in China!
Stop organ harvesting from living people in China's labor camps
http://www.faluninfo.net
Falun Dafa, also known as Falun Gong, is an ancient Chinese
self-cultivation practice, based on the principles of
* Truthfulness * Compassion * Tolerance *
Great for improvement of health and mental well-being!
http://www.falundafa.org
It's pretty much the status quo being hyped by HopeGirl:
QuoteOur goal for QEG power out was 10,000 Watts. The tests show that the potential power out far exceeds this goal! The QEG in Morocco as shown in this video has been tested to produce almost 20,000 VARs energy out with 600 Watts energy in. After the output VARs are converted to Watts in the QEG 3rd phase of development, (which is a relatively simple phase) this will be equivalent to over 33 times overunity. This is a conservative rating as the input can be varied to 1,000 Watts energy in to produce 30,000 VARs energy out.  There is A LOT of power in the QEG core!
The above is hardcore snake oil salesman talk.  There is NO power in the QEG core.
The new clip:  https://www.youtube.com/watch?v=Jhd0Ebygriw&feature=youtu.be
The new "Version 2" test document:  https://hopegirl2012.files.wordpress.com/2014/05/morocco-qeg-june-2014-test-and-measurement-report-v2-011.pdf
Note the results in the first test in the clip are even worse:  The input power is about 600 watts, and the output power is 93 watts.   That's about 16% efficiency.  Nothing positive there.  (I am making a reasonable assumption that they are getting the RMS voltage and current values from the DSO, but they never show the real-time RMS values being displayed on the DSO in the clip itself.)
This quote from Version 2:
QuoteAlthough the voltage (Ch 1 – yellow) has a fairly regular waveform, the current (Ch 2 – cyan) has an irregular waveform with a 'double
peak', possibly indicating that the system is not fully tuned. The voltage is 14kVpk-pk / 4100VRMS (using a 1000X probe) and
the current is 1.63Apk-pk  /  0.5ARMS  (using a 10X probe).  It is difficult to be certain of the  phase difference between the
voltage and current  due to the double peak nature of the  current waveform.  This  set-up  gives a  Reactive Power  of
22.8kVARpk-pk or 2050kVARRMS, and a Reactive Power Efficiency of 338%.
The waveform they are talking about is shown below.
"due to the double peak nature of the  current waveform."  They think there is a "double peak" but in fact there is not truly a double peak at all.
"Possibly indicating that the system is not fully tuned."  What the heck, this waveform was captured when they were IN RESONANCE.  That's just an amateur speculation on the part of the Fix the World gang.
"It is difficult to be certain of the  phase difference between the voltage and current  due to the double peak nature of the  current waveform."  Hah!  Caught again!  It's is plain as day that the phase difference is almost exactly 90 degrees.  James Robitaille, you have met your match in this circuit and you can forget about all claims to being an "engineer" as far as I am concerned.
"Reactive Power Efficiency."  WHAT?  Never heard that term in my life.  It's a made-up BS term.
So, James and the "team of engineers" are failing to understand the scope waveforms.  BUSTED!
With respect to the reactive power, the famous "VARs," they are stating that the goal is to turn the reactive power into real power. The argument is that there is more reactive power than power input, and all that they have to do is convert the mysterious reactive power into real power.  Now that might sound plausible to a lay person, (and they may donate) but it's not true.
One more time, this is a nonsensical proposition.  It's something that can't be done, and they are trying to suggest that it can be done.
