0 Members and 84 Guests are viewing this topic.
F_Brown
Hey Roger, good to see you chiming in.  How did you work out the variable coupling coefficient?
If the foldback is due to some interaction between the primary and secondary, my model without any secondary consideration is going to fail to simulate that phenomenon.  Because the foldback is showing up in Jamie's video as well as the models that take the secondary in to account, I expect now that is the case.
I watched half of the video then decided to download it because it kept halting over my slow internet connection.  At about 10:30 it sounds like Jamie said there's 14.4 kilo watts of reactive power in the primary.  I find this absurd, for there is only a few joules of energy oscillating in the primary at the resonant frequency.  We've been all through this earlier on in this thread about how misleading it can be to attempt to claim that the RMS current in the primary times the RMS voltage in the primary yields any kind of a useful figure, because the current and voltage are 90 degree out of phase.  This was Joseph Newman's strategy, and he failed in spite of over two decades of claiming and trying to prove that his device could ever convert the huge amount of "Reactive Power" oscillating in it to a form that could be used to do something more useful than just deflecting meter needles.  In other words he failed to show his device ever output any more power than was input to it.
Aside from that Jamie appears to have a four channel scope there.  That is capable of using two channels in differential mode with a current sense resistor to display current data, and the other two channels for voltage tracking.  I would ground the connection between the two starts of the windings, and insert the current sense resistor on one side of that ground connection.  The voltage there would be low.  I been wondering all along why Jamie's allowed that point to float in the first place.
pmgr
Quote from: MileHigh on June 14, 2014, 08:26:49 PM
Can you reduce the size of your graphic to make the page more readable?
@MH:
Shrunk the picture.
Very nice write up. I don't think I could have written it down that clearly!
@F_Brown
The fold back (dip) will also occur without having a secondary.
PmgR
Help stop the persecution of Falun Dafa in China!
Stop organ harvesting from living people in China's labor camps
http://www.faluninfo.net
Falun Dafa, also known as Falun Gong, is an ancient Chinese
self-cultivation practice, based on the principles of
* Truthfulness * Compassion * Tolerance *
Great for improvement of health and mental well-being!
http://www.falundafa.org
Pmgr:
Thanks and thanks and I hope that James M. is reading!  lol
F_Brown
Quote from: pmgr on June 14, 2014, 08:59:14 PM
@F_Brown
PmgR
I'm having trouble getting my model to produce such.
pmgr
Quote from: F_Brown on June 14, 2014, 09:11:37 PM
@F_Brown:
The location of the dip can be fine tuned by the LCR parameters of the primary. If it goes off to one side, it will look like you have a single current peak with a small bump on it and you will not be able to see a clear dip. You should be able to fine tune the position of the dip with the capacitance value so it will show up exactly in the middle of the primary current peaks and then you should see a clear dip.
PmgR
