0 Members and 50 Guests are viewing this topic.
isim
@Synchro1
"Show us evidence of "Distributed Capacitance" in your super single wrap! Practically everything you say is total bull crap."
Every body know that even a straight wire has inductance and capacitance, don't you?
This is called linear inductance and distributed capacitance. ( with the earth as second conductor and with others parts of the same wire)
So, when you wind a wire to make a coil, each part of  surface has capacity with all other part of the wire and even with all part of universe. Fortunatly, only the parts sufficiently close one to the other have have a significative influences.
So a single coil has "Distributed Capacitance".
(https://www.google.fr/#q=Distributed+Capacitance+of+coil)
This is also why coils for high frequency are made in a herringbone kind of pattern and are called honeycomb coil or Basket winding (see http://en.wikipedia.org/wiki/Basket_winding). Just to minimize the "Distributed Capacitance"...
Quote from: synchro1 on July 31, 2014, 02:43:44 PM
"Nikola Tesla also worked with such non-inductive windings. For example if we take a Bifilar coil into account, with opposite windings, the magnetic field created by one winding is equal and opposite to that created by the other (under ideal conditions) resulting in a net magnetic field of, which makes the self inductance of the coil zero. However, the self capacitance would be exist and much higher than a single wound coil. Such a coil is capable of holding more charge than a single wound coil. When operated at resonance, the distributed capacitance of the bifilar coil is able to overcome the counter force normal to coils, inductive reactance".
The web page you keep citing is full of errors and misconceptions about Tesla's work, as I have tried to explain to you before. The passage you quote here is a perfect example. If you examine the Bifilar Patent you will see that the windings of the Tesla Bifilar flat pancake coil are NOT OPPOSITE. The current flows in the same direction in all adjacent windings. The passage above describes a HAIRPIN BIFILAR when it says "opposite" and "zero inductance". This is not a TBF winding characteristic, as I have demonstrated several times with both flat and solenoidal forms. Then it jumps the track and starts talking about a characteristic of the true TBF winding. The author confounds the two types of winding. From MarkE's transformer comment above, I am not even sure that he knows just which winding we are talking about. I have "multifilar" toroidal gate transformers in my TinselKoil 2.0 for example, as an easy way to get oppositely phased drive signals for the main H-bridge mosfets. These trifilar phase transformers have three separate and equal windings: one 16 turn "primary" and two 16 turn "secondaries" that are not electrically connected to each other. But both the Hairpin Bifilar and the TBF windings are actually Monofilar: there is one continuous piece of wire with only two ends.
Quote from: ariovaldo on July 31, 2014, 03:35:51 PM
Good afternoon!!
Any good news? ???
After long recovery I'm back...
Since I still have my equipment, any suggestion other then just put it away?
Ariovaldo
I am glad you are back! What I have been demonstrating is the extraction / conversion of the "OU in VARs" that exists in resonant tank circuits, by using an inductively coupled tuned resonating receiver or Receptor circuit. This method loads the primary tank, naturally, but does not result in collapsing the resonance like a direct resistive load will do. Please check out my latest set of videos. I've shown: running a DC motor on the true output of the resonant system; attaining high voltages without the use of any inductive collapse spike collecting; and various methods of constructing Transverters and Receptors for this system. I am operating at much higher frequencies, though, but the principles will be the same. You will just need larger components to get down to your own resonant frequency range.
(grins evilly)
Quote from: isim on July 31, 2014, 05:02:26 PM
@Synchro1
Heh.... and people think I use cardboard crap and random garage sale technology.
Angelic
TK,
There is no better source of materials than salvaged electronics. You never know what you might come across. I just salvaged a dual flyback setup that I wish someone could help me figure out before I end up dissecting.
