0 Members and 58 Guests are viewing this topic.
Farmhand
Quote below from the QEG Canada web link MileHigh gave. Outright lies in bold, it's donation fraud I tells ta !
QuoteFor the moment the QEG is a prototype, which simply means that it is under development. However, it does achieve over unity, which is why teams of qualified engineers around the world, in Taiwan, Germany, Morroco, Florida, China and else where are building QEGs right now and experimenting with it, modifying it, in order to achieve maximum over unity output of usable clean power
It takes approximately 1000 watts to run the QEG and when functioning at maximum efficiency can output 40,000 watts of clean non-polluting quantum energy.  (The average Canadian home requires 26,000 watts for heating and electical needs).
What exactly are "electical" needs ? hahahahhaa Proof read the post to encourage people to donate their hard earned money
their fraud did they ? Nup no one will notice, target market won't anyway.  ;)
Farmhand
So here are some wave forms from the right tank of my new setup while driving a fluro and also the bottom right wave form is
the left tank tuned to double the frequency of the primary and secondary, Also the scope reference and probe placement is at
the top. I inverted channel 2 otherwise the voltage and current was about 180 out of phase, I found that interesting.
And eventually turned on the bandwidth limit on channel two it was set to off, so I turned it on at some stage, not sure when.  :-[
Seems the V and I phases are almost "in phase", how can that be ? Isn't reactive power "out of phase" ? Even in a tank ?
I know it's still rough but I think the measurements are close surely.
Current trace is still the voltage sensed across a 0.1 Ohm 5 Watt power resistor.  :-[
I can provide larger images of any particular wave form if any one want's it.
DOH !! I made another mistake with the scope the Math trace is still set to A + B from some differential measurements I tried
earlier.
P.S. Top right hand shot shows "475 Watts of in phase power" in the tank, the input was 12.4 volts at 0.3 Amps = 3.72 Watts in.
So just say 3.8 Watts input. 475 Watts divided by 3.8 Watts = '125 x OU in VARS'.  ;)  ::)
I wonder if I can double that to 250 x the input power. OU in VARs pffft.
Actually with no load the tank activity capable on each side will be enormous, but the input will go to around 20 Watts I'll wager.
Umm, anyone want a look at the lamp power ? Or should I not even look just in case it shows 10 Watts or something. rofl. It's a
10 Watt Lamp anyway, not good enough.
ACG
Quote from: MileHigh on August 17, 2014, 03:28:03 PM
There is an update from Canada from four days ago on the money page:
http://www.gofundme.com/qegac-quantum-energy-gen
I note they have raised $2015 out of $8000.  Even though they are "out of pocket, " when it doesn't work I think that they should return all of the donated money back to the contributors such that they are even more out of pocket.
We will *hopefully* see what happens.  There might be a boat in a marina somewhere in Montreal that needs a new anchor.
If any of the "Canada" team is reading this.  Consider this suggestion.... Buy the damn parts yourself.  <Gasp> such shocking words!  Did he just suggest to do what people have been doing for thousands of years, and actually spend money?  Yes I Did.
Should not have taken 3 months for a team of engineers to accumulate a few grand of their own money.
QuoteI am involved in a global movement to bring quantum energy to the world.
This should be interpreted as: I am involved in a scam to siphon donations from the world.
PCB
FH:
QuoteSeems the V and I phases are almost "in phase", how can that be ? Isn't reactive power "out of phase" ? Even in a tank ?
Not sure what current probe you are using but:
"The output voltage of the Rogowski coil is equal to the derivative of the instantaneous primary current. In
the case of a sinusoidal primary current this voltage output is 90 degrees out of phase with the primary current"
http://www.dynamp.com/ldadocum.nsf/c2270fbdd892ac3e86256e75000ad88a/e710af6d3e0f6255862565d7004b19db/$FILE/Report.pdf
Hope this helps!
Farmhand
Well I don't have any non inductive resistors as yet so I'm still using a 5 Watt power resistor of 0.1 Ohms resistance, I try to
measure it's inductance with my meter but my meter doesn't have low enough resolution 2 mH lowest setting with three decimal
places so it should read in single uH and it does down to a few uH. Surely that cannot cause a 90 degree phase shift.
The secondary voltage probably is 90 degrees out of phase with the primary current. But the tank itself at resonance. What
should the phase relationship between the voltage and current be nearest ?
Does anyone else think it's odd that in the scope shot of the left tank the harmonic oscillations show more current during the
lower voltage free ringing cycle than during the higher voltage driven cycle ? Would that be because the free ringing cycle in
the left tank is 90 degrees out of phase to the right hand driven phase and 90 degrees out of phase to the fundamental or
the primary frequency and so no back emf comes from them to restrict it or something ?
I'll try not to ruin anything and get some load shots with the scope set properly this time.
I'll get the current voltage phase and power before any HF light activity, during the first HF light activity before enough power
is applied to "strike" the tube into full conduction, and during full conduction to try to get roughly the load power resulting from
the 3.8 Watts input.
