Groundloop
Quote from: MarkE on December 08, 2014, 06:07:10 PM
This garden path leads nowhere.
Mark,
Why do you think that? Back to the question, do we need to use any energy to switch the input to the output
by shorting the middle coil?
GL.
MarkE
Quote from: Groundloop on December 08, 2014, 06:10:40 PM
Mark,
GL.
GL you are building a house of cards on top of one impossible premise after another.  There is no meaningful conclusion that can ultimately result.
Closing the connection on the middle coil requires energy transfer to magnetize the right hand transformer.
isim
Quote from: Groundloop on December 08, 2014, 04:01:42 PM
All,
Now the next question.
Do we need to use any energy to switch a AC signal from L1 and to L3 by shorting the L2 coil?
(I know there will be some losses and the output will be lower than the input signal.)
GL.
In an ideal transformer, if you short-circuit  L2, you  short-circuit the power who is connected to  IN...
Farmhand
Considering that we know energy and for that matter (no thing) can be created from nothing, then if more core material is added
at the maxima of the magnetic part of the L/C oscillation and that increases the inductance, the only things that could happen
would be limited, 1) the period would be changed, 2) the magnetic field energy would take longer to transfer to the capacitor,
3) if the system was in resonance the tuning would be changed.
The logical result is usually quite simple and as correct as can be. I mean what else could happen ? Gee wizz.
Groundloop
Quote from: MarkE on December 08, 2014, 06:40:01 PM
Mark,
Agree 100% on your last sentence, but that was not the question. The question was, do you need to use any energy
(or actually very little energy) to short the middle coil to be able to transport energy from the input
to the output.  Don't bother to answer. You can actually transfer AC or pulsed DC from the input
to the output by shorting the middle coil. So this setup is a on/off switch for that energy transfer based
on the status of the middle coil (shorted or not). And you do not need to spend any energy to switch the middle coil.
In real life you need to use an transistor or relay to switch the middle coil, so by using very little energy, you can switch
on and off a large energy from the input to the output. So I'm not building anything based on an impossible premise.
I'm basing my thought process on real life research that I have done on magnetic amplifier setup using
toroid cores and coils during the past two years.
GL.
