0 Members and 73 Guests are viewing this topic.
F_Brown,
You make a lot of good points and I will make a few comments.
For starters, a varying inductance in a circuit is unusual, but in theory it would be possible to jury-rig somehow.  It will not produce energy in any way, shape, or form.  The classic example is a spinning figure skater with extended arms.  When he or she retracts their arms, they speed up.  They speed up because energy is conserved.  That is literally an example of a mechanical inductor where the inductance changes with time.
I am not comfortable with the concept of power recirculating in an LC tank.  An LC tank is just a dynamic way to store energy, and power is a different thing altogether.   For example, you can say that at the peak voltage, the capacitor is storing 10 Joules of energy.  At peak current, the inductor is storing 10 Joules of energy.  When the energy is transferring from one to the other, it's still just 10 Joules of energy.
So in the real world, and in the case of the QEG, and using arbitrary values for illustrative purposes, you can state that the LC resonator in the QEG stores 10 Joules of energy, and there is a bleed off of power due to the wire resistance of 1 watt of power.  Since we are assuming that the energy in the LC resonator remains constant, then by definition the spinning rotor is injecting 1 watt of power into the LC resonator.  I will repeat, any varying inductance is just a side show, it does not affect the fundamental energy dynamics of what is taking place.
So going back to the QEG, when you are not in resonance, you still have an LC circuit that has the capability of storing energy.  It will be less energy when not in resonance at some given set of frequencies above and below the resonant frequency, hence the bleed off of power will be lower, and the adding of power will be lower.
We will assume the drive motor is 90% efficient.
Something like this:
                                              Energy stored in LC -  Power bleed from LC - Power injection into LC - Drive motor power
Below resonant frequency                 1 Joule                     0.1 watts                     0.1 watts                     0.11 watts
At resonant frequency                      10 Joules                     1 watt                         1 watt                       1.11 watts
Above resonant frequency                 1 Joule                     0.1 watts                     0.1 watts                     0.11 watts
So, if you are following this, the big jump in the LC resonator voltage at resonance just means it will store more energy, and as a result there will be a bigger power drain due to the wire resistance, requiring more power from the drive motor.
Now what happens when you add a light bulb load?  Since there is high voltage in the LC resonator, that will facilitate exporting power into the the light bulb load.  We assume that the peak voltage across the resonator will decrease because of the load.  That means less energy is stored in the resonator.  More critically, since you are at resonance, that means the LC resonator is more "receptive" to pumping more AC power into it at the right AC frequency.  The power is pumped into the LC resonator + light bulbs by the spinning rotor of the drive motor.
So you end up with an energy and power balance that looks something like this:
We will assume that the light bulb load draws 20 watts of power.  (I am always using simplified values for illustrative purposes)
Resonance will light bulb load:             5 Joules                  20.05 watts                20.05 watts                  22.28 watts
So what this means is that when you hit resonance, the LC resonator facilitates the transfer of the mechanical power supplied by the motor into the the LC resonator and into the light bulbs.
If this is indeed what is truly happening, then the whole thing is either a) a con job to rake in money with no accountability, or b) a complete and total farce by people that have no clue what they are doing.
Note option b) is somewhat akin to a form of criminal negligence.  The law does not or should not allow you to be so stupid or so ignorant that you end up hurting people financially.
F_Brown,
QuoteThe value I got for the recirculating energy in my tank sim is so close to what James is claiming as peak output, that I'm getting the impression that James reported the value of the recirculating energy in the tank circuit as dissipated energy in the output load of the circuit.  Perhaps he is thinking of this as "generated energy."  A trained engineer would simply know better than to make that mistake.
Somewhere in the FTQ/HopeGirl online information they state that James M. Robitaille's name is on about 20 patents related to his working career.
For starters, I don't know if he truly is an engineer.  Does he have his diploma and is he a member of the engineering governing body in the United States, I don't know.  That is to be determined.
With respect to his name being on about 20 patents, in many cases there is a team of people that get their name on a patent.  It's actually the company's patent because when you work for a high tech company you typically sign an agreement where you give up any intellectual property that you develop over to your employer.
So, that means that James M. Robitaille did not necessarily develop the IP that went into the 20 or more patents.  He could have just been a bench technician that assisted the lead engineer or engineers on a given project.
I am just making it clear that until definitive information about his credentials or lack or credentials comes forth, then don't assume anything.
Jimboot
Quote from: MileHigh on April 20, 2014, 05:54:26 PM
F_Brown,
I think it was in the SA interview, that it was stated he was a "self taught" engineer.
Quote from: Jimboot on April 20, 2014, 06:02:07 PM
You can get criminally prosecuted if you try to claim that you are an engineer when you aren't one.  If you are an ethical person you don't call yourself an engineer, even in passing, if you don't have your diploma and your papers.
