stivep
Quote from: joel321 on September 01, 2015, 02:43:25 AM
If you understand how social humans work, there are a lot that follow the "group"...
meaning even if he may be correct in a lot of things as a lone individual, he will still follow the crowd as to not stand out or to not get singled out.
Yes* ( read explanation of *)
Typical to the crowd:
In order to look smart in  that interaction. (conversation blog discussion etc.)
-typical to most   members of  crowd    is to point at  his/her credential.
That is done concentrate attention of the crowd and to let the crowd know that this guy  is not that stupid in the subject discussed
And that is exactly what I do , while  I try to explain my  standpoint.
"I have good few years of  psychology behind me and my wife  has  master  of psychology from one of the most prestigious
European universities.:"
now  my standpoint:
Yes, safety  and comfort of interaction  as well as self correction  of  common thinking
makes individual visible and knowledgeable. Always obey wishes of rich and powerful.
So I'm going to act as  subgroup of the crowd  the ,scientifically oriented  crowd- (the crows)
For that crows it it is not important ,if that what they do  is   right or wrong.
QuoteIt is the crowd  known as:
prestigious or
leading  or
smarter in area of science.
It is the crowd that  fallows   politically correct  comfort of the biggest scammers of all times The Rulers.
It is the crowd that, if Rulers are to stupid than  crowd  does not talk , (as the will likely lose  job  and found dead or insane. )
Only rebellious  scientists who have undeniable prove in their hands, are the one who,
if lucky to be alive than will have full access to benefits
of their art.
In many cases  many of them , have been tried if mental hospitals, or court conviction, to find if  that makes them   to be silent.
Albert Einstein was incredibly lucky guy ,as his invention was in area of  revolutionary theory, and did not affect wealth of Rulers.
It goes all the way up as serious as loosing their jobs for going against the NORM.
Yes  it is fear (known also as discomfort of non-uniformity with the crowd driven to become temporary standard  by stronger  fraction, or by the ruler )
It does not matter how you say it, LIGHT MUST CURVE!.
No it will not .
Quote from: joel321 on September 01, 2015, 02:43:25 AM[/size]So you are telling me that light is a perfect straight line through all matter?
Yes
Even water bends light...even a mirror reflects light
explanation of word BEND  picture below.
Because of duality of word "bend " this term must be excluded in   the rest of discussion as invalid or incorrect.
water does not "bend" light
Quote from: joel321 on September 01, 2015, 02:43:25 AM.
Changing the "path" of a photon is bending.
Yes only when it comes to  straight line alteration of direction to another  straight line form of continuity (or continuation)
Bending a photon itself is some other type of phenomena.
No such thing as bending photon.
https://en.wikipedia.org/wiki/Photon
.. in  particular, the photon model accounted for the frequency dependence of light's energy,
and explained the ability of matter and radiation to be in thermal equilibrium.
https://en.wikipedia.org/wiki/Thermal_equilibrium
But maybe I don't understand light that much. How do you explain fiber optic cable bending?
I mean photons bouncing around the cable but still bending? LIGHT BENDS...will it go straight in a black hole?
photon moves  in straight light only
http://www.quora.com/Why-do-photons-only-travel-in-straight-lines-and-not-bend
explanation of light in fiber-optic cable look attached photo  below.
From what I can understand the neutrinos pass through all KNOWN matter.
BUT WHAT I CAN PREDICT IS THAT THEY REFLECT TOO just like there is a mirror to a laser light.
This reflection = curving. Which means 100% light curves OR REFLECTS in a controlled manner.
1.No such thing as 100% reflection.
2.Well the easiest to study is man made neutrino not complicated  subject at all.
nuclear decay can make neutrino
Depends  form the process, but that is   usual  to plenty of naturally accruing  earth isotopes .
You can  make neutrinos in your own house  no big deal.
Quotesome of  properties:
Neutrino oscillation is a quantum mechanical phenomenon whereby a neutrino created with
a specific lepton flavor (electron, muon or tau) can later be measured to have a different flavor
https://en.wikipedia.org/wiki/Neutrino_oscillation.
QuoteCan a neutrino undergo elastic collision with a particle participating in weak interaction, such as an electron, a nucleon, or other lepton or a hadron,
such that the direction of neutrino movement changes by 180 degrees?
If yes, what is the direction of the neutrino spin relative to its direction of movement before and after the collision?
What is the direction of neutrino spin relative to outside frame of reference before and after collision?
Can a neutrino be reflected by a pi meson, seeing that the pi meson has no spin and therefore cannot change it?
Reference https://www.physicsforums.com/threads/can-neutrinos-be-reflected.815765/
Yes
however:
Quotesuch that the direction of neutrino movement changes by 180 degrees?
No. The probability for exactly 180 degrees is zero.
The probability for around 180 is very low. This is just Rutherford scattering.
Well yeah that is theoretical but the smartest people in the world believe in them.
Yes I explained  crowd behavior at very top of article.
And, to be honest, they may be correct but, to me, a black hole could only seem black
because they believe the black is nothing there where it could just be another type of star that is outside the light spectrum of our eye sight.
Black- is acronym for "nothing  that goes  out"
nothing  that manifests its presence by any active means, and at the same time does not serve function of an reflector.
-e.g. horizon  can be seen as it is  acting as  an reflector  in order for us to see  we need to have photon that is reflected from passive  body as well.
-eg. motion detector  registers rate of change between thousands  of mirrors  molded on plastic cover of th  detector
( easy to spot it when you look at that plastic  having   lightbulb from the other side.
Even though  that  motion detector  operates  in the region of   infrared light there is still reflection needed.
Black  hole can be detected as suffers  lack of reflection
Quotehttp://www.crystalinks.com/black_holes.html
we cannot detect black holes by light that is emitted or reflected
interesting article I must read it too.
It has been proven that an mantis shrimp sees more colors than a human eye
color is just another frequency of electromagnetic spectrum and belongs to visible light region.
colors are mostly described as physically  able to be detected by human  eye.
different colors are  different frequencies.
shrimp might have better electromagnetic wave  receiver than human eye.
everything related to  photon is electromagnetic wave including  lightm x-ray and gamma.
How about teaching the school kids about multiverses or invisibility? All of that dark matter must have
STRAIGHT RAYS OF LIGHT GOING THROUGH IT EEHHH!
Invisibility was discovered  quite few years ago and is   working.
In military  technologies  invisibility is perfectly know and researched .
and now it looks like piece of cake... nothing special.
1.Material less controversial:
https://www.youtube.com/watch?v=5ZOV_9Jirp0
2.Material more controversial:]
https://www.youtube.com/watch?v=5BvzktPxdg0
3.Material  very much controversial:
https://www.youtube.com/watch?v=AnEW2KN5zNw
https://www.youtube.com/watch?v=wGgUZgCeOzQ
Quoteinvisibility is the state of an object that cannot be seen. An object in this state is said to be invisible (literally, "not visible").
Two teams of scientists worked separately to create two "Invisibility Cloaks" from 'metamaterials' engineered at the nanoscale level.
They demonstrated for the first time the possibility of cloaking three-dimensional (3-D) objects
with artificially engineered materials that redirect radar, light or other waves around an object.
that information is incorrect.
government  is as close as  possible to say nothing about something, but is saying  something  only because  saying nothing is just stupidly simple way  for  invisibility  to  become a controversy.
And that is what government does not want.
They do not want any conspiracy theories or another 9/11 unexplained.
The only things  not explained but found that  they  exists  makes people think and research it.
Government  want you to be just stupid crowd.
Government  does not represent you however you might think it does.
The typical example of altering science upon  rulers request.
like  one of choices below:
-stay  alive
- be in prison
- be insane,
- lose  job
- lose   everything just be dead
Now, what is making those photons look dark? :P
lack of photons
or insufficient amount of photons to be noticed
or direction of photons is not into  your sensory device ( eye)
Photons can not crisscross or accumulate energy even if they are at the same very frequency
that means they  will never see each other.
The only way  photon can be notices is when it  strikes matter. and deposits  its en energy  there.
So space is  all big place for photons and its energy like incredibly dense soup
but as long as there is no matter there is no chance for that soup to bombard it.
Gamma photon  is harmful just because if its eV  ( keV, Mev) energy level.
so is X=ray
and only if matter is involved,( if there is no matter there is no harm .
Harmfulness of  high energy  photos comes from its ability to brake nuclear bonds of an atom.
for biological bodies   is  illumination and ionization of DNA and RNA.
It is 100% fact that a magnet is not 100% balanced...or should I say, the magnetic fields
correlated to the N and S are not 100% balanced...you can call those "legs".
Can you think of a magnet as ATOM and the atoms magnetic fields? Same thing, just understand that a magnet has two nucleus.
no I can not.
( however I need to think about it and do not start to  express it in foolish way)
All I am saying is that the ROOT of "renewable energy" comes from the big bang and THAT we have not discovered 100%
all anymals in the abyss of the oceans to TRY TO GET FAT HEADED
I understand mechanism  of knowledge:
We know not enough (about something  or anything,)........... to be able to benefit from what we do not know as of yet.
again the phrase is:
We know not enough .......... to be able to benefit from what we do not know as of yet.[/size]
So that was always true and always will be.
One single person telling me that there are no aliens in this world while they don't know 100%
all animals in this world? Lol I don't think you know how DEEP I'm thinking :P
I do not know.
However typical assumption is  that since earth is placed  at the very much province of the galaxy or universe than
the biological or intelligent life must of be in most advanced form delivered closer to the center of universe than it is on its  edge.
By that  assumption is that we are in the process of evolution the most  primitive creatures comparing to the" other  central galactic aliens ."
Wesley
joel321
Stivep,
Everything that you are telling me seems like you do agree with me but at the same time you disagree with me hehehe.
Like bending of light – somehow you are trying to tell me that light cannot bend while at the same time you give me answers that suggest that light does bend. IF you think about a laser beam, say, 3mm wide, are not the photons inside the 3mm laser beam bouncing around? Or ARE ALL photons in the laser going 100% straight in all directions? If the photons bounce around a light beam, that means that light bends period. All known human mater bends...rocks, air, glass, plastic, diamonds, human bones, etc bend...ALL matter has a percentage how much they can bend but they all BEND! It just has too since a photon has to pass through a lot of sub atomic particles. Like, for example, a light beam going through glass, the clear glass is made of sub atomic particles, so it has density to keep it's structure...if a photon just goes 100% STRAIGHT through a piece of glass, how can the photon go through it straight if the glass gas mass?
Now think how light CANNOT go thought a solid object while sound WAVES CAN! Not this means that the photon STOPS and cannot penetrate such objects while SOUND WAVES can! Sound waves don't travel in a "straight" line BUT YET they can penetrate objects that light cant. So there are things that are invisible to light but not to sound. But that also means that LIGHT DOES BEND. This means that sound waves DO BEND light. AND light can bend the ripple of sounds waves too.
If you think about the sun producing light, why is the ball of light 360 degrees and not a square? :P
You also have to think in the math and in the brain how black holes BEND LIGHT too. But you also have to ask yourself WHAT CREATES BLACK HOLES? And where are the sound waves around the sun?
So we can "see" that a photon NEVER travels in a straight line because it has objects to bounce around that influence other particles. HECK now that I think about it, WHAT CREATES A PHOTON? And does a PHOTON by itself glow in the middle of darkness? IOW, there are no photons in dark spaces?
This is really that not hard to "see" really. It is just a matter for all to understand this and move on in the evolution instead of trying to lay a blanket on those whom are not capable to understand such things so they can suck money from their paychecks.
Is not like "they" are trying to educate the world (global children) so they can learn everything there is to learn from what evolution has thrown at us BUT truth is they teach you what is known so they can take your money.. :)
And now I'm going back to a COP>+ and now I'm thinking is MONEY COP>+? (can one make money for infinity?) .....heck! If one can become a millionaire (make money) from the resources of the earth that is COP>+....UNTIL there are no more FREEE resources to get (oil, gas, water, etc)...
So that means an over-unity device exists INSIDE the earth, but outside the universe since the universe is more COP>+ than the earths COP>+...
I mean how does energy work COP←.....that's just 100% truth. There is a COP>+ in order to keep on living via the GIVEN resources (returnables) from the earth.
Many people, just want to "debate" about their two cents BUT the truth is always there :)...the truth has road blocks too just like a photon does too?
SoManyWires
if one thing can be said about that argument in defence of the QEG team,
it is that scammers are sometimes master debators that will sometimes throw in really tragic
heart touching examples of their own abuse that may or may not have ever happened,
because they are victims of mental illness.
and having a mental illness does not make someone a bad person.
but if they use lies to try and market some profitable angle,
that is when honest people are most interested in paying attention to it
before it results in them or others paying money towards such disabled people,
in the wrong less effective manner.
while they talk and talk and talk themselves into a master debatory circle until they expect people to just move on,
rather than to lay a blanket on those whom are not capable to understand such things
so they can suck money from your paycheques. and they are willing to do this by any means possible.
such as witt's scamming corporation has and still does,
along with complete scamwads like mr sino the grande pinnacle of pyramid dillusions that is another
qeg affiiated scam thats also still running titled, UN SWISS INDO.
mr sino promises all his 'delegates' and followers too, just over a million dollars each.
go figure.
joel321
I logged in to edit my post because I just had a eureka moment as to why we can see through glass – and the answer is because our eye balls have a clear lens = our eye balls are able to see through the same clear things equal too (or close to) the building blocks of our eye ball clear living tissue layer. That is why we can see through glass. Our eyes are genetically encoded to see through the outer "clear" layer of our eye ball hence anything else that is close to the same mechanism is "see through".
Which this why makes perfect sense http://i.imgur.com/DlRA0ht.gifv
This is amazing but eye opening at the same time...the eyeball CANNOT "see" what the thoughts can too. The thinking in the brain does not require to see through objects....hmmm, what do they call it, consciousness?
This whole GREEED is just a road block in the ULTIMATE truth of understanding the truth. If we can predict the future, going against the GEQ will not stop the truth! Why? Because the QEG is not one machine, it is quantum energy generator...which there are a lot of them in the galaxy.
Those people that cannot understand the DEEPER things, ahem, SoManyWires, they don't know how money GREEDY sides of things work.
