3v OU Flashlight
Started by 4Tesla, April 14, 2014, 02:55:28 PM
T-1000
Quote from: verpies on April 16, 2014, 07:57:21 AM
I cannot verify your assertion that the inner winding is composed of only one part.  As he unwinds the inner winding, a small group of turns is left behind the unwind-point, while the underlying copper tape is being exposed.  The remaining group of turns is attached to something and he cannot unwind them like the rest of the winding, so he breaks them with a screwdriver.
This resembles winding layout depicted on Diag.2.
See the photo below:
At this point I can add from what Delamorto said:
The underlying copper tape is connected in series with primary coil and the secondary coil is all on top after.
Also I see all these LEDs self runners interlinked (I might be wrong) with same NMR effect... I already explained my thoughts in
http://www.overunityresearch.com/index.php?topic=2358.msg37723#msg37723
P.S> The http://www.overunity.com/14378/akula0083-30-watt-self-running-generator/msg397475/#msg397475 is one you should look at for circuit diagram and PCB layout. Also it contains mistakes in circuit diagram what needs to be fixed. And semenihin-77 IS Delamorto ;)
magpwr
Quote from: T-1000 on April 16, 2014, 08:44:23 AM
hi T-1000,
In series to copper tape (with ~2mm gap)may sound a little misleading for others as i noticed there is only one "solder point" on shiny copper tape which is easy to spot from video.
Although it may not be wrong to say "in series" since it is also connected to magnet wire and thicker copper wire leading outwards.
Haha nice you already drawn it below. :)
T-1000
Quote from: magpwr on April 16, 2014, 09:02:29 AM
hi T-1000,
In series to copper tape (with ~2mm gap)may sound a little misleading as i noticed there is only one "solder point" on shiny copper tape which is easy to spot from video.Although it may be not wrong to say "in series".
Hopefully Delemorto's quick sketch will help you:
T-1000
Quote from: semenihin-77 on April 15, 2014, 12:50:41 PM
>:(  Считай витки.
Consider the turns.
http://www.youtube.com/watch?v=bYEuV-ji4tk
Thanks for video, now someone need to count turns in slow motion mode.
Also as you mentioned, the amount of turns are different each time and until you get same effect  (it took for you to rewind 500 times) so ampmeter showed less and less power consumption until it gone down to 0...
Непережывай, тут люди повторят и усовершенствуют схему после таво как на столе будет иметса рабочая копия твоево фонаря.. ;)
verpies
Quote from: T-1000 on April 16, 2014, 09:04:13 AM
Has he seen my "not so quick sketch" of the bobbin's cross section?
It would be nice to have those connections of wire windings to the copper foil on that diagram.
