3v OU Flashlight
Started by 4Tesla, April 14, 2014, 02:55:28 PM
Raycathode
Quote from: T-1000 on July 09, 2019, 07:59:53 AM
I am talking about high Q achieved in the coil. Also to keep low current draw the resonant circuit needs only a fraction of power and feeding spikes instead of sinus/50-50% square wave is more than enough. So feeding pulse train with like less than 5% duty cycle signals also helps with low current draw.
And did you ever tried to hammer ferrite with the second spike on the peak of BEMF pulse?
T100 Hi
Now that is an interesting idea if your piezo xtal will fit in with the buzzing ferrite
but it would require to have a holding container as some of the older pot cores use to have and a sort of washer around the edges so the center of the piezo can move.
Raymondo
rakarskiy
Text from the discussion post of the video.
QuoteAssembled this scheme, about 5 years ago. The circuit operates with a very low current.Current not more than 5 mA. The circuit is very important for the length of transformer wires. The optimal length is 12-13 cm, tried with other transistors does not work. Only works with 2Т603А. The scheme gives impulses 85кГц, in fact the author of this show. The led limits the voltage to 2 volts. If you replace the led to a resistor, the voltage can be raised to 3.5 V. the current of more than 5mA to raise is not possible. Many thought over this scheme, the best result from it not to squeeze.
https://www.youtube.com/watch?time_continue=42&v=A2zrJi63ErE
kolbacict
Nothing shines. an hour of time wasted. :( >:(
ARMCORTEX
Yeah... These bullshit things "need tuning".
Please translate this.
https://overunity.com/12736/kapanadze-cousin-dally-free-energy/21600/
We'll find a way to this flywheel bullshit if its true what we saw on video.
There has got to be a way to make free energy with a flywheel. The dean drive can produce an invisible force in the vacuum of space,  this is insane and absurd but true, there has got to be more secrets to this.
rakarskiy
Quote from: kolbacict on September 05, 2019, 02:24:09 PM
QuoteThe optimal length is 12-13 cm, tried with other transistors does not work. Only works with 2Т603А.
I think the author of the video didn't say the ferrite ring core material also matters, the length of the wires and probably he made the cut.. More I think if he collected a second time using time he wouldn't have come out. A third-party radiation source is impossible because it is impossible to excite a closed core at a distance. Despite the fact that the battery to hide in his scheme nowhere.
