The Bessler Wheel, mystery solved.
Started by gurangax, April 24, 2014, 02:40:13 PM
MarkE
Quote from: forest on May 07, 2014, 03:55:57 AM
Sure, but did you watched video ? Once mass is in air the lever or any other more complex type of levers connected to wheel are FREE from load of this mass, if you build device for such situation , i.e. to become balanced WHEN this mass is in air (falling due to gravity) then it become continously unbalanced except the moment when mass is falling, it may be descripted as continous falling down due to gravity. Then surely the impact of this mass on the propel lever (!) will thow in air another mass and so on...
Never falling down mass....
If you believe such things and cannot be persuaded by conventional physics, then the solution for you is to try and build something that takes advantage of your ideas.
Airstriker
Quote from: gurangax on April 30, 2014, 10:02:15 AM
I found that Bessler can be hilarious at times for example this is what he wrote
"If I arrange to have just one cross-bar in the machine, it revolves very slowly, just as if it can hardly turn itself at all, but, on the contrary, when I arrange several bars, pulleys and weights, the machine can revolve much faster, and throw Wagner's calculations clean out of the window!"
What is the meaning of cross-bar here? Is cross-bar simply an X formed of two bars (so in fact M138) or do you simpy mean a bar hanging between two points (crossing the wheel)?
gurangax
Quote from: Airstriker on May 08, 2014, 06:42:42 PM
only 1 bar.
Airstriker
Did you find a way to utilize this idea? Or is it something completely different?:
http://youtu.be/FWU8GY1RQT8[/color][/font]
gurangax
Quote from: Airstriker on May 09, 2014, 05:34:07 AM
Completely different.
