The Bessler Wheel, mystery solved.
Started by gurangax, April 24, 2014, 02:40:13 PM
Password for what exactly?
Quote from: gurangax on May 23, 2014, 12:47:07 AM
password is BB793C6896DA118104EBFB97B5DA373C.
regards
p.s I will be answering questions later
Regarding your video. It shows a small weight dropping a large distance and a big weight rising a small distance. I can't seem to find the magic.
gurangax
Quote from: PIH123 on May 22, 2014, 03:14:57 PM
When the bet was first made, Gurangax replied:
"Wager or not, I still will disclose it before your said time limit."
Seemed pretty certain back then. Now he has also recently replied that it may be sooner.
So why hasn't it been or isn't going to be sooner. It makes no logical sense.
I am going to be the richest and most famous person in the world and errrrrr, Sept 15th seems like a good date to pluck out of the air (bizarre).
The fame gained from being the principal participant in this thread will be miniscule by comparison.
I cannot realistically think of a single reason why June 1 has to be a hard and fast date.
Except maybe........................................
From following this thread from the beginning, I believe Alan (AB Hammer) is the replicator (the clues are there if you look for them - PMs, a suggested joint unveil, Aan's impressive building skills, mutual interest in the subject).
Gurangax states that the replicator is using his own design.
It seems he believes that Alan has the best chance of anyone on this site of producing a working design.
(for what it's worth, I also feel that AB has the best skills / understanding of anyone here in this subject, and yet after many years, he is not quite there.....Yet)
Waiting till June 1 gives Gurangax the best opportunity to be presented with a working design without having to share what he has produced.
If the replicator fails to produce on time, then it is the other persons fault for not stepping up to the plate. Or their design was wrong / misunderstood. And best of all, in order to avoid embarrassing the replicator, he/she won't of course be named.
And it will certainly buy more time for someone like Vortex to hand him (as requested) a diagram of a working model on a plate.
It is actually quite genius really if you ask me.
btw he is not AB. so you can stop your accusations.
regards
forest
thank you gurangax  ;)  the magic happens when you throw away any mechanical joints (forcing balance) as I expected. I hope everybody see it now, especially those "skilled in art"
btw I think this is slighly wrong animation. If I'm correct there should be a very slight minimal time when lever is FREE FALLING in air without touching anything. It is not obvious here..
Of course I'm not expert here, please bear with me. It resemble to me the David and Goliath story. A small rock doing huge impact due to the proper timing of releasing mass from contrifugal force.
Please , please ...you must see this ! I'm only uneducated simple-minded person ! It's impossible you don't found it ealier
gurangax
Quote from: forest on May 23, 2014, 02:51:55 AM
Now do you understand?  :)
gurangax
Quote from: broli on May 23, 2014, 02:20:39 AM
you need to find the file which needs the password
regards
