COP 20.00 (2000%) Times, Reactive Power Energy Source Generator,
Started by synchro1, May 07, 2014, 01:25:54 PM
hartiberlin
hartiberlin
Hi Mario,
many thanks for your replications.
Please can you do a video and explain in it and show us, how you do it ?
Many thanks in advance.
Regards, Stefan.
listener191
Attached is the data sheet for the LTC-6993 pulse generator, they cost about $3 a piece, £2.5 from Farnell in the UK part no 1848053 for the rising edge triggered type and 1848055 for the falling edge triggered type.
The rising edge type is the delay from the zero cross point to where you want to switch and then triggers the falling edge type on the falling edge of the pulse. The falling edge type generates the pulse width you want. As you may want to keep all the pulse widths the same, the control inputs can be tied to the same control voltage.
Barry
hartiberlin
I think the whole control circuit could be done by using a small PIC processor
as with the AD-Converters from it you can dedect zero crossings and only the
MOSFETs Switching circuits must be designed with drivers for the
right potentials to switch the MOSFETs the right way.
I think by the end of the year we could all heat our flats with this Reactive Watts for instance
use 1 Kwatts
and still deliver 300 Watts back to the utility, so your power meter turns backwards ! ;)
hartiberlin
I still wonder, what this open core choke will do and how it is connected ?
Maybe it is just put in parallel to the load resistor ?
Paul Babcock was telling, that he lived in Alaska and during the winter months it was bitter cold.
Then he got himself an old petter diesel generator from the junkyard for 100 US$ and
used it to power his cabin in the woods.
When he one day put an inductive lamp balast load in parallel wiith his ligh bulbs suddenly
the generator speeded up and the lights were brighter and the generator needed less fuel.
See it in the pictures.
Maybe the open core choke ( probably from a modified microwave transformer
where the upper core piece is removed can be used to tune the inductance of this
choke by pulling up or lowering the coil in the core....
Best regards, Stefan.
P.S: I´hope Aaron does not mind posting these pics from the sales PDF file which came
with the video....but when we heat this winter our flats with this reactive Watts power
then we can all donate to them from the saved electric bill money...
or you get yourself the sales package at:
http://bit.ly/serpslecture
