KARPEN PILE
Started by Philip Hardcastle, May 22, 2014, 10:41:32 PM
profitis
You will get a voltage.that is due the NEMCA effect.how long it will take to recover I don't know but it absolutely will recover to some stable reading. You should never show voltages here that haven't been shorted FIRST then adequately rested because that is their true equilibrium value.that voltage that you showed in your last video is in fact meaningless because that was before shorting.hydrogen dissolves in platinum,it does not dissolve in carbon although it adsorbs loosely with it hence there will be something.with gold here you will without a doubt get something stable and permanent.gold does not dissolve h2
pomodoro
OK I shall disconnect short tomorrow and show the voltage after some hours. Hydrogen will then be pumped through while shorted.  I'll still go for roughly the same voltage on Pd/Pt and C even with hydrogen.  I reckon all the catalytic Pt electrode does is equilibrate ultra fast, the C will have a much weaker exchange current , so its potential will initially also depend on any other contaminating couples, but once those reactions are exhausted the same potential as the Pt will develop.  I actually hope I'm wrong BTW.
Next post will have the result of the disconnection and rest phase for this oxygen karpen.
profitis
Ok before you do any hydrogen experiments or further oxygen experiments there is one setup I will insist that you do to prove your loyalty to science and to the overunity crowd pomodoro.it requires platinum(black) and platinum etched under air in Either acid or base.are you willing to do this dastardly simple experiment( you have all ingredients at hand)
profitis
When you show on camera the above experiment(Pt black vs Pt) result it will render all of what you just said above null and void.you cannot possibly tell us that platinum vs carbon or platinum vs gold will die out if platinum vs platinum works like a bomb
pomodoro
Quote from: profitis on August 11, 2014, 11:30:07 AM
What are the exact details of this mother of all tests?  Isn't it supposed to be shiny vs black?
