Akula eternal lantern 4
Started by MenofFather, June 01, 2014, 01:15:57 PM
Pirate88179
Quote from: MarkE on March 05, 2015, 08:33:36 PM
Is it the demons or angels that are responsible for the false positives and negatives?
Both, ha ha.
hartiberlin
Quote from: Void on March 05, 2015, 08:50:43 AM
My suggestion that it might be a good idea to test Akula's devices of this type with a Geiger counter is based on this idea as well. :)
I'd be interested to hear from Stefan on this. Stefan, have you viewed any of Akula's devices in person, and if so, what was your impression?
Do you have any further info to add to this discussion?
All the best...
Well, I have not yet seen the device myself, but I hope I can visit them still in the coming months.
In this moment Akula is only here in Germany in the Stuttgart region for only 10 days.
But he will come back later longer this year.
Arthur Tränkle now has this new prototype and told me, that it is already running since last friday.
so now a week long.
He also told me, that the device is also running wrapped in aluminiumfoil and also
put in a metallic chocolate box....
So the claimed tapping of the earth magnetic field is rather vague, although it might just tap the
longitudinal waves part of the magnetic field of the earth magnetic field, that might not be able
to be shielded by an iron-metallic box ?
Also Arthur told me, that the ferrite material need to be specially heat treated in an oven...
Maybe the Q of the resonance is then better when you do such a heat  annealing ?
Or maybe it was shock cooled then ? I don´t know....
Maybe one should try to heat the cores with HHO gas...
or it really depends on the excited radioactive decay of the ferrite components ?
Maybe there are some kind of Morray type radioactive decay material inside the ferrite
or Akula put something around his transformer wire and coated them with some radioactive
active betay decay material ?
As Morray succeeded exciting his White Swedish stone material with High Voltage High Frequency bursts
from local radio stations via his antenna to give off excited Beta decay radiation into his circuit
and this worked like a negative resistance amplifier, it might be possible, that Akula also stumbled
onto this phaenomen and now has succeeded in tapping it....
We will see...
Regards, Stefan.
Void
Hi Stefan. Thanks for the info on Akula's device, etc. My thinking is along the same line
as yours, that Akula is possibly doing something special with the ferrite cores. I continue to
experiment with ferrite cores to see if I can find any interesting effect along these lines.
All the best...
MenofFather
QuoteSo the claimed tapping of the earth magnetic field is rather vague, although it might just tap the[/size]longitudinal waves part of the magnetic field of the earth magnetic field, that might not be ableto be shielded by an iron-metallic box ?
I think, that it running on energy from backround enviroment. Like human running on air. If no air, human dead. But to run on air, you must put air in moutm you must open your mouth. Akula generator opening "mouth" to get energy from enviroment.
MarkE
Quote from: hartiberlin on March 06, 2015, 12:12:17 PM
so now a week long.
For those who believe in this LW business, set-up an antenna for such things and measure the available energy density.
Annealing is the LAST thing that anyone should want to do to a soft ferrite.  Soft ferrites are made by rapid quenching so as to avoid forming large crystal domains as occurs when one anneals material.  Annealing is great for making tempered glass.  For efficient ferrites, it is a bad idea.
Rapid cooling is the normal method of producing soft ferrites.
There isn't much in your typical ferrite in the way of radio nuclides.
We will see...
Regards, Stefan.
Ultimately, we will see that Akula is using a battery.
