Akula eternal lantern 4
Started by MenofFather, June 01, 2014, 01:15:57 PM
Tink
Quote from: turbogt16v on March 09, 2015, 02:13:26 AM
How do you know that?
If you are able to produce even 1 unit that works ,you would do your best to draw perfect scheme for everybody to reproduce,
and help others to reproduce,and not try to blame it on some excuses why its maybe working maybe not ....
And if you claim to make more than 20 different units ,and no one can reproduce it ,
than it obvious to normal thinking people ,that his purpose is to distract people from proceeding in wright direction.
And the only problem is  that he is not alone.
So you don't know.
Synergy is the key to free energy.
synchro1
Quote from: MarkE on March 09, 2015, 01:54:34 AM
Antenna + tuned LC tank + rectifier = basic narrowband receiver.
@MarkE,
Dr. Stiffler wraps his coils in an aluminum tray, places them in a microwave oven. Joe Tate's "Ambient Power Module" needs a long antenna. You can't have it both ways; A hidden battery, then radio waves! Stephan says his tester has Akula's unit wrapped in tin foil too. He would notice a stupid battery.
Dr. Stiffler demonstrates a different "Spatial Resonating Frequency" that is an inherent characteristic of the coil like the "Self Resonating Frequency" that's a function of Earth's magnetic field. Akula's been ridiculed for implying the "Earth Field" can have any efffect on his generator at all.
plaxius
Quote from: synchro1 on March 09, 2015, 12:44:36 AM
@turbogt16v,
Here's a video by Dr. Stiffler where he illuminates an LED with three coils alone and no battery and no transistor:
https://www.youtube.com/watch?v=JIIhgHTEoM0
Stiffler goes on to demonstrate the importance of "Spatial Resonant Frequency" where the longitudinal axis of the solenoid coil is in line with the North and South poles of Earth's magetic field.
https://www.youtube.com/watch?v=Jv-Q-_IszCg
Akula's claims are not too far removed from Dr. Stiffler's test results!
VASMUS is similar concept ..
https://www.youtube.com/watch?v=9pC7W_aJiOk
Void
Quote from: synchro1 on March 09, 2015, 02:09:13 PM
Yes, I would think the first thing any reasonable person would do is at least do some basic and simple checks with a voltmeter
to check for a hidden battery.  While someone who is very gullible might not do such basic tests, I expect most anyone
who is going to be potentially spending any amount of money or promoting such a device would do such a very obvious test such
as checking for hidden batteries, and probably do a lot more in depth checking on the circuit as well. This whole thing about
hidden batteries really doesn't seem too likely at all considering that Akula's German business partners have been working
with Akula for quite some time now. So, if not hidden batteries, then maybe a disguised super cap, but to power that many LEDs
and the driver circuitry for a week (and possibly longer now) from a super cap or two is not too likely, as well, and would probably get
picked up when checking for a hidden battery anyway. :)
As an example to help get a rough idea, lets say you have a 25F super cap disguised as a lower value electrolytic cap.
Super caps of that capacitance size are usually rated at a max of 2.7V.
So, if fully charged, you have a stored energy of 91.125 Joules in the 25F super cap (at 2.7V).
Over 24 hours (86,400 seconds) that would supply an average input power of  91.125J/86,400s = 1.055mW
The LEDs plus the driver circuitry itself are likely consuming a fair bit more power than that, so even
a 24 hour run time with a 2.7V, 25F super cap would not even work. A whole week of continuous running and you would need
quite a bank of super caps, which the circuit clearly does not have. Also, a super cap takes a fair bit more than just a quick connection
to a battery to charge right up to 2.7V. Really, with even just a little thought it becomes clear that a hidden battery or super caps are not
very likely at all here. ;) The circuit has also been running for at least a week while wrapped in aluminum foil as well, so
even the possibility of a hidden wireless power transmitter appears to be unlikely, and I would guess they have probably done
a few more tests/checks to rule out a hidden wireless power source.
So, what is left?
All the best...
MarkE
@MarkE,
We have two different claims and two completely different demonstrations, but you demand that they both must have the same explanation.  That's just silly.
Dr. Stiffler's "Spatial Resonating Frequency" is ordinary electromagnetics.  It results from materials reflecting and propagating electromagnetic waves.  I don't know what object you believe has a SRF that varies with the earth's magnetic field.  Outside of flux-gate magnetometers I am pressed to think of a device that would have such a behavior.  Anyone's claim that they: in a desktop sized device located anywhere near the surface of the earth and therefore immersed in both the relatively weak and very constant magnetic field of the earth extract induced electric energy energy from that field is false.  No time dependent change in B x l means no induction.
