Thanks to ALL for your help!!
Non-Coherent Access to Hidden Precession Energy in Ferromagnetic Material
Started by Smudge, June 03, 2014, 06:59:45 AM
Smudge
Here is another of my old papers suggesting means for accessing energy from electron precession.  It assumes that in a very fast change of applied magnetic field the individual electron precessions are not able to instantaneously adjust their precession frequency to the new value, and in this temporary "non permitted" state they supply an anomalous longitudinal magnetization.  It may be noted that in normal magnetic switching circuits where current is switched into a coil, the current rise-time (hence also magnetic field rise-time) is slow because of the low impedance drive circuit.  Only on switch-off do we see a rapid field change (and that time constant is likely determined by stray capacitance).  There are many claims for OU associated with fast back-emf spikes and my paper may offer an explanation for where the anomalous energy comes from.  Enjoy!
Vortex1
The file opens fine with Wordpad, all figures and text are readable.
Smudge: Thank you for posting this as it is an area I have been experimenting in.  I will give it a thorough read.
My plan is to use a normal coils and out of phase coils to create a bucking orthogonal field timed with the normal coil. I am using MnZn  material and a very simple low power excitation circuit that will also easily detect the presence of anomalous energy.
I am also looking at any voltage developed at the ends of the ferrite material.
Kind Regards, Vortex1
Edit: Ok read the paper, looks very good. What is the current state of your experiments with this?
Smudge
Quote from: Dave45 on June 03, 2014, 07:30:21 AM
Cant open doc files  :(
Sorry I sent the wrong file.  Should have sent the pdf version so here it is.
Vortex1
May I present this circuit for OU testing?
I also have variable frequency circuits that do not require an externa FG (frequency generator) drive, very simple two transistors.
