Thanks to ALL for your help!!
Fundamentals of FREE ENERGY generation with a transformer. Experiment #1
Started by tarakan, June 12, 2014, 06:22:08 PM
vasik041
Quote from: ALTECHLAB on June 13, 2014, 10:21:54 AM
see Akula OU generator with ferrite core...it's working!
ALTECHLAB How do you know for sure ?
I think there are all signs that Akula is a faker :-)
tarakan
If something is working and you have physically built and witnessed it, send me a PM with more information.
If you live in United States I want to come and check if it is working or not. I will popularize the circuit as soon as I replicate it myself.
tarakan
You had built it and it worked? I will pay. Build me a replica and mail it to me.
tarakan
Here is what I want to build.
I need to choose a Divider IC for the clock, a Divider for the input, and a buffer IC to store an impulse as a "1" and output that "1" in a line of "0"s as the clock is ticking.
ARMCORTEX
Ok, I have designed amplifiers before, I have some college education in basic electronics, but I consider that mostly basic and easy. Like you my skill is self taught.
It looks like you have good logic and are clever individual, I doubt engineers will help you for ''free'', and alot of engineers would probably be unprepared for your task.
I trust you know how to program a microcontroller, and have good skill with non-programmable IC logic gates, the fastest I ever used were the 74LV series.
The thing you gotta know about VHF 100 MHZ and above is that you need specially designed stubs on a pcb, to avoid reflections, coaxial tubes, self made type high current.
You cannot poison your signal generator by your own radiation.
I have a good book from an ex-mit student that explains all the effects in simple terms, If you are interrested let me know, you will learn about loci diagrams and propagation effects.
The logic circuit, looks doable, and you should be able to do this without too much complications if you make a good pcb, plz read about pcb design guidelines for high frequency.
This I understand so-so, I apply these rules a bit like voodoo, and ''covering all angles''. Most of the times it will be ok if you obey the rules.
The amplifiers, you will not be able to do properly without proper calculations, you may not even be able to measure what signal you got correctly, there will be complications.
