Flippin' Mechanical-Magnetic-Gravity Device
Started by FreeEnergy, July 07, 2014, 08:26:13 PM
FreeEnergy
mscoffman
The original idea would be an excellent design for a robotic rover spacecraft on a "windless" dry rocky body liked Mars, Moon or larger
Asteroids. It gets you above the dust and muck. Why have the camera mask up there when the whole rover could be?
It's in a class of the "footed wheel" rovers.
Now back to our regularly scheduled broadcast...
Bumblebee
Quote from: FreeEnergy on July 07, 2014, 08:26:13 PM
Hi all,
I just came across this http://www.youtube.com/watch?v=R8NXWkGzm1E
So I thought instead of using batteries to power it why not use magnets?
I believe a smot (http://www.youtube.com/watch?v=vvhX7BF9pL0) will work on this device.
You would have a smot on the track top and bottom where the ball rolls..
the smot must only be strong enough to roll the ball horizontally, the smot must not be strong enough to pick up the ball's weight.
the top and bottom track should have a little more distance than the picture shows so the ball falls a bit more so its away from the magnetic field of the top smot.
So when the device flips the ball falls to the bottom smot and the process repeats..
any thoughts?
I believe the video is faked  :(  for this reason....... If the motorised cylinder is heavy enough to lift the track, how does the track lift the cylinder?
FreeEnergy
Bumblebee I think you're probably right.. :-/
AB Hammer
Quote from: Bumblebee on July 09, 2014, 04:36:48 AM
I will have to disagree. It looks real, and the tracking lifting the cylinder is a fine balance and the action of the motor shifting the weight in the cylinder is trying to climb as it flips angular momentum helps to create the action.
The weight in the cylinder must be on an  axle with the weight spinning around it. As the weight at the end is in its furthest position it flips and when the weight is in its least position the track lifts the weight due to its position.  I do think it maybe under a controller due to the jerky action but it doesn't have to be.
To duplicate as is. This would be my approach.
Alan
PS FreeEnergy;  Don't give in so easy.   Chastisement LOL
Alan
