FREE ENERGY is here to stay
Started by that_prophet, July 08, 2014, 12:33:51 AM
that_prophet
       Just think of it this way, if you use 100 AC generators/motors, which have absolutely no load on them, and it is just the fluid friction of the bearings as resistance. Then you wind up the rpm on the mini pulleys to 10s and 100s of thousands of rotations. What kind of voltage are we talking about, in Ezekiel 1:16 it is a description of how UFO motors look like.
   I cannot believe how mankind is so caught up in the lies of evil spirits, that they simply will not accept God's Gift of free electricity multiplication. This technology is supremely simple, using variable pulley sizes to multiply the number of rotations, which is extremely important when it comes to AC electricity.
       Especially if we are working towards levitation,,,
I would have thought this was enough to start a following for sure,,,
I guess that people just cant shake off the evil voices saying """WHAT ABOUT TORQUE""""
there is no torque problem, it is divided out into 1,000 s of RPM
your pulleys are simply being used to multiply  # of rotations,,,,
which means you are multiplying your AC electricity
it is truly that simple
Quote from: TheCell on July 21, 2014, 11:33:36 AM
@that_prophet
if you have a working model:
publish your approximate location here, and allow people to visit you to make power measurements.
We cannot judge your device having no clue what's going on there.
Personally I cannot wipe out this all as nonsense . Many similar patents which cover this subject and many yt-videos. But I consider this as a time and money consuming setup, which if it fails , you probably have done better to put solar panels on your roof with a storage battery bank. This would work for sure.
lumen
"trying desperately make sure that we never re-discover this technology
this is found in Ezekiel 1:16 "wheel in the middle of a wheel"
when describing how a UFO works "
Only using gearing or pulleys was not how it was done.
Go buy a "Gyro Wrist Ball" on Ebay and study how it works, you will be much closer.
Think of converting centrifugal force to Gyro RPM for free.
that_prophet
Are you trying to tell me that if you put just a spark of DC electricity,
Into rotating a DC motor one single time,
With a 100cm circumference pulley attached,
With a belt on it that is big enough to encompass the 100cm pulley,
As well as 10 1cm circumference pulleys,
With AC motors-generators attached,
That the 10X100 = 1000 units of AC power,
When put through a full wave bridge rectifier,
Does not have the voltage to more than rotate your DC motor once
That is one spark of DC electricity in,
That gives you 1000 sparks of AC electricity out
http://free-energy.yolasite.com/
that_prophet
As well as 10 X 1cm circumference pulleys,
that_prophet
PLEASE ALERT THE WORLD ABOUT THIS HIDDEN TECHNOLOGY
((( NEWS of this ancient technology will change the world as we know it)))
I have the MOST IMPORTANT NEWS
to share with you + this whole world. Unfortunately this NEWS has two sides to it, one is the best, most awesome, and the other one is the most seriously scary. Yes, of course I will tell you the best half first. This best NEWS is that FREE ENERGY http://free-energy.yolasite.com/ is easy to be produced, and can + will even lead to anti-gravity. Yes, that's right, this free electricity multiplication technology will eventually lead us to a way to even defeat gravity. (proof = this tech is found in our Holy Bible, where it is describing the workings of a UFO motor)
This FREE ENERGY technology is soooo easy to explain + use, as you only have to put one spark of DC electricity into this Electricity Multiplication mechanism. That is because you only have to rotate your DC drive motor, with a 100cm circumference pulley attached, one single time. This large pulley has to be attached to a belt, rope, or even string,(in a pinch) strapped around it, that is pulled through ten of the one cm circumference pulleys. Each of these ten mni-pulleys, has an AC generator attached to it, producing 10 X 100 = 1000 units of AC electricity = sparks. This free energy technology works with only putting one spark of DC electricity in, which returns you 1000 sparks, units of AC electricity out. These 10 AC generators all turn easily, with no load on them. (except the load of your one DC drive motor + this is divided by 1000 output sparks = practically zero)
- (Of course you will have to connect your AC output through a full wave bridge rectifier, to convert from AC to DC, then plug your DC drive motor into this output)
Now I must tell you the bad half of this new FREE ENERGY technology. Since this technology is so simple to build, use + understand, then there MUST be a bad-evil influence that was hiding it for all these thousands of years, since Ezekiel 1:16 was written at least. How else can you explain this super simple free energy technology being hidden from mankind for so long. Yet, even this sad news has a shinny lining to it, because our universe has everything balanced, this means that there is also a good force to counteract these evil forces. Yes, there is a God, and Ezekiel 1:16=(a wheel in the middle of a wheel.), along with many other fulfilled prophecies, (please read Armageddon by Grant Jeffrey) proves that He Is the God of our Holy Bible. http://beliefstoliveby.yolasite.com/
This God of our Holy Bible, is so awesomely good, that he has given this end-time Joseph-(that_prophet) free energy, along with other important pieces of information, to share with our world, (like "I AM" is the name of God), just before the final 7 years of Tribulation. This Tribulation MUST start before 2020, http://2020-vision.yolasite.com/ + http://doorschristmustpassthrough.yolasite.com/ (2019.1 = when the door closes on our generation, which we are told that we are allowed to know, in (Mat 24:33) just before He assuring us that "But of that day and hour knoweth no man" (Mat 24:36)
(( PLEASE COPY + PASTE THIS TO EVERYBODY YOU KNOW ))
I love my Father
He teaches me all that I ask
I hope that I maybe able to shake up this world
I want to dissolve this evolution fairytale
I would like to know how these scientists explain
how does our moon remain in orbit
with the constant addition of space dust
we do not hear much about space not being empty
but it contains a steady stream of dust partials
messing up the trajectory of its orbit
+ why is there only about 6000 years worth of dust on the moon
(our moon is GOD's Creation hourglass = proof positive age of earth)
possible lame excuses
Was the space dust just a recent happening – why?
Was there a space storm that blew the dust off, every few thousand years
After a few thousand years, it solidifies + becomes part of surface
The sun burns it off, with extreme solar flares, every few thousand years
http://aliensandghosts.yolasite.com/
http://decimationofthisevolutionfairytale.yolasite.com/
http://evolutiondebate.yolasite.com/
http://myiqchallenge.yolasite.com/
