Ultimate proof of Magnetic Vortex, free book and videos
Started by TheoriaApophasis, July 13, 2014, 04:20:12 AM
SeaMonkey
Quote from: TheoriaApophasis on August 06, 2014, 10:11:50 PM
How salty of a sailor?
regular,......or extra salty? >>>  ;D
Well, I reckon my level of "saltiness" is about equal
to a "pinch" when compared to the Real Old Salts-
The Bo'sun's Mates and the Gunner's Mates. ;D
Technicians were tolerated by the Old Salts, but they
considered themselves to be in an entirely different
league, if not Navy (Wooden Ships and Iron Men.) ;)
Some were so salty they left a trail of flakes as they
walked the deck giving the bluejackets a piece of
their mind...  Language so coarse that flames and
smoke belched forth from their mouths.  A true
sight to behold. :o
And then there's the one about the SeaBats... ::)
TheoriaApophasis
Below: Broken ring magnet "re-attached" as a ring, but NOT AS IT WAS BEFORE IT WAS BROKEN, but HOW it can exist after broken. On right, the black markings indicate that this portion of the ring was originally located on the other side. While this LOOKS 're-assembled' it is not; it is the only way (other than on top of each other in a double crescent) it can rest AS A RING.
The same would be true of a disk magnet broken in half as well. This is the action of dielectric counterspace in how "magnets" DO and WILL 'self-fold' and decrease as much space as possible. On left is the field view of the flipped (self-flipped) broken ring magnet.
TheoriaApophasis
Quote from: gravityblock on August 06, 2014, 11:55:07 PM
Prof. Muller has a publication, titled "Experimental Test of the Normal and Retrograde Railgun Accelerators", where the aluminum rod advanced in the forward direction as expected (away from the battery bridge) whereas the steel (magnetizable) rod advanced backwardly when they're allowed to roll.  When the same system is setup vertically, however, and the transversal rod is suspended on a balance (without rolling), no retrograde behavior is observed for the steel rod. Both, aluminum and steel rods, moved in the forward (expected) direction. The conclusion is that rolling of the steel rod is essential to observe its retrograde motion.  I have tried to locate this publication in the past without success.  The below snapshot, as found on the World Science Database, shows an abstract for this article.
Gravock
Lovely stuff,    .......can I borrow your rail gun for testing?    Mine is broken  ;D
kidding.
I know a person who is in the "INSIDE OF THINGS",  I will leave it at that. ...........
he explained an upcoming technology ,......a radioactive power-cell that draws enormous energy of high radiation when exposed to some special layers,.....the device which is the size of a couple of oil drum and goes into a prototype TANK, and that large radioactive cell charges up an array for using a rail gun on a TANK
advantages are that it can generate enormous power with very little heat, and the tank can carry 5X plus as many projectiles since there is no (obviously) power and shells to pack around.
Apparently it works like the radioactive decay power cells on our deep space probes however in a radically diff. manner he wont say, and I dont get,....it is capable of enormous power draw which can be activated and shut down as needed.
gravityblock
Quote from: TheoriaApophasis on August 07, 2014, 12:24:57 AM
Earlier today I was thinking about that also, but couldn't find the right words to properly describe this phenomonon.  Good experiment, and this confirms what I have noticed myself in previous experiments!  This experiment says it all.  It's almost as if space creates one of the so called "fields", such as the N pole of a magnet, while the matter, is induced with the opposite pole of the same magnet (cause and effect, or inversion of cause and effect).  Is this what you refer to as space/counter-space?  Together, the fields create a space, or more correctly, we should say "projects a space", such as in projecting a holographic 3D world.  There is only one thing in this universe that is "real", and that is Spirit/Consciousness.  Everything else is an illusion.  The adversary of God has enslaved our spirits/consciousness in this false simulated perceived reality of a holographic universe.  The truth shall set you free!
Space, which had been transformed into matter (deformed space) endeavors to return to its former state of primordial space in accordance with the law of rotation of masses in a magnetic field. This reconstitutes the energy that had been used for condensation of the matter, turning it into light, whose wave energy goes on decreasing until the moment of entropy is reached. This is what takes place on the Sun. Leaving aside the reaction that they bring about on the planets, the Sun's discharges into space are, in a sense, matter or deformed space returning to its original state of primordial space.
In the first instance, an oscillating charge superimposed on an infinite point supplied the power that brings about the deformation of space and the Sun, by an opposite process, turns it back into energy, thus re-establishing the balance.  That is why neither matter nor energy exist, but only deformed space, which is called matter, and what you call energy is nothing more than a phenomenon of transition between primordial space and deformed space.  This transition between primordial space and deformed space occurs within the "quantum transitional speed of 1.094 megahertz m/s".
An electron is an integration of electromagnetic waves.  We can define the electron as deformed magnetic space, propagated in wave form.  Now an electron, as a wave form, is moved in an (anti)clockwise circle. In this spiraloid movement it has a discontinuous wave surface rather like a spiral spring. The movement itself is not discontinuous, but only appears so by virtue of its spiralling movement. It also shows a magnetic phenomenon cancelling out the charge on one side which gives an observer the impression that the energy moves in jumps. Further, it is subject to the outcome of the difference of charge due to this magnetic effect, as well as the result of its rotation.
The so-called orbits K-L-M'0 are nothing but stationary electrical waves in the field of the atom, each having its particular wave structure and frequency. It is known that waves of varying length do not interfere with one another as is shown by radio, even though they occupy the same area of space.  Even Heisenberg felt that he could not account for all the electronic movements in an atom. He saw that this minute electron seemed to be ubiquitous, appearing at all points in an orbit at the same instant. Being unable to locate the point in space where it was to be found at any given time, since it appeared at all points, he developed his "Uncertainty Principle".  The photon (or in your terms, "charge") carries momentum.  The Heisenberg uncertainty principle simply says that the photon has volume.  Calculation shows that the energy and thus the mass is distributed uniformly throughout the structure. The same fact applies to the distribution of momentum.  Quantum indeterminacy and a probabilistic universe based on the wrong assumptions of the Copenhagen interpretation has been proven false!
If the electron is a wave form having its origin in space, the whole concept of modern science would fall to the ground. It would contradict the principal argument of Planck's theory which asserts that an electron is a particle whose energy is stepped up in "quantic jumps".  It would also lead to the collapse of our conception of light and all the mechanics of relativity.
"The old has been made new again"
Rock On!
Gravock
TheoriaApophasis
Quote from: gravityblock on August 07, 2014, 01:33:26 AM
Space doesnt create anything, the radiative fields produce space posterior and resultant to discharging fields.
Since nothing charging is part of what gives MASSIVENESS to mass/ matter, the entire empirical and phenomenal cosmos is nothing but discharging radiative posterior resultant of charges in discharge.
Charges have no space,  transverse dielectromagnetic fields are (phi x psi = Q Planck / electrification) are not the fundamental forces of nature, which are dielectricity / electrostatics and magnetism (discharge/ radiation).
time and space as per fields only applies to
1. transverse charges  (TEM)
2. the rate of induction / capacitance of a given medium(s)
JC Maxwell discovered the proportionality between dielectricity and magnetism was  1/C-squared
This is where Einstein stole it from (and from Poincare') , and then he RA*PED IT, and RUINED IT
Its interesting to think that nothing in the visible universe is anything but the manifestation of radiations from charges that ARE or HAVE discharged.
;D
The Photon doesnt exist, it is a name given to what is/was not understood, the so-called "electromagnetism" has a Z-axis radial dielectric component.  Those pulses of dielectricity resultant to the wavelength / frequency are what was deemed (and is deemed) a "photon" .
That momentum you speak of dielectric inertia,  some electrical engineering texts still call electrostatics "electrical inertia" .
VIDEO 34 Uncovering the Missing Secrets of Magnetism. THE MISSING SECRET OF LIGHT PART 1
https://www.youtube.com/watch?v=vBKZOl_dRlQ
