Ultimate proof of Magnetic Vortex, free book and videos
Started by TheoriaApophasis, July 13, 2014, 04:20:12 AM
0 Members and 18 Guests are viewing this topic.
tinman
Lets look at this in a different way.
Who here can explain how the homopolar motor work's,and why the same cant be achieved using PM's ???
If the line's of flux(as we call them) are straight on the PM from north to south(using standard modle here),and the magnetic field produced from the wire is the same all around the wire,then why dose the magnet rotate(if using the rotating magnet type motor)in one direction?
We can place the wire in the north region,and the magnet will spin in one direction. We can place the wire in the south region,and the magnet spins in the same direction-so what pole is produced from the wire?.
Why is the force from the wire only in one direction?-where is the equal and opposite reaction?(force)
Added picture.
Bob Smith
TA,
Thanks for posting these pages - very enlightening, and always best to go to the original sources when presenting a case (as you have done).
Okay - so the mag and electric fields coexist, and neither creates the other, and their cause is "time variable electric charge and currents."
Two different questions:
This would imply that magnetic fields have a frequency(ies), which is/are directly related to the frequency of the "time variable electric charge and currents"?
Every once in awhile, I hear about magnetricity, which seems to me to be based on the idea that magnetic "current" can be harvested and used to light up lightbulbs and power motors, etc.,.  Most explanations I find are either steeped in new age ideology and terminology or articulated with antequated notions of electrons spinning around atoms or are secretly vague/abstruse or a mix of all three.   My question:  In your opinion, if magnetricity were possible, would it have to do with influencing or tapping into the strength of the dielectric plane?
Edit: If the dielectric plane is where the "pinch" is located, is this not where the real power is?
If I'm too far afield for this thread, and you choose to defer to another thread, I'll respect that.
Bob
nathan97
Dave45
Thought you might be interested in this.
This coil was powered up with ac 12 volts placed in water and frozen.
If you look closely there are two electric fields but that is because of the winding, the coil was wound and powered to cancel the magnetic field.
Although the magnetic field is not completely canceled its in a bucking configuration, the reason for the two fields.
I have one powered with dc will look it up.
Dave45
This is the field that actually transfers energy from one coil to the next in a magnetic loop not the magnetic field.
The magnetic field is more like an axle this field spins around.
