Ultimate proof of Magnetic Vortex, free book and videos
Started by TheoriaApophasis, July 13, 2014, 04:20:12 AM
0 Members and 66 Guests are viewing this topic.
TheoriaApophasis
Quote from: picowatt on August 22, 2014, 09:36:33 PM
account for the lack of indicated heat in the area covered by the sticker at 1:14?
I said sticker in the video, but its just colored electrical tape, RUBBER.      Its an insulator.
considering the differential spread is 3-5 degrees,    Yeah, insulating 3-5 degrees from thick MIL rubber  isnt so hard   :o  ;D ;D ;D
picowatt
Quote from: TheoriaApophasis on August 22, 2014, 09:45:48 PM
Interesting...
So you are saying that the nickel plated neo magnet, an object of high thermal mass and excellent thermal conductivity, is actually warmer than its surroundings and therefore radiating heat, and that the applied tape is acting as an insulator and preventing the heat from escaping where the tape is applied.
If this were the case, why does the magnet not appear to be any warmer than the the holding fixture, CRT, or ambient at c.a. 0:20 and 1:07?
PW
gravityblock
GB,
So "yes" or "no", do you see the magnet being at a different temperature from its immediate surroundings at the mentioned time slots? (ca 0:20 and 1:07)
As well, how do you account for the lack of indicated heat in the area covered by the sticker at 1:14?
PW
IR imaging device sees differences in the heat energy from the objects in its field of view. If everything in the frame were exactly the same temperature, no contrast would exist so no image would be produced.
Gravock
picowatt
Quote from: gravityblock on August 22, 2014, 09:59:39 PM
Gravock
[/color]
You are correct.
And because their temperatures are indeed so similar, only a ghostly, barely visible outline of the magnet, holding fixture, and CRT are visible at the indicated time slots.
PW
gravityblock
Quote from: picowatt on August 22, 2014, 10:02:09 PM
You are correct.
PW
I never disagreed with you.
Gravock
