Ultimate proof of Magnetic Vortex, free book and videos
Started by TheoriaApophasis, July 13, 2014, 04:20:12 AM
0 Members and 84 Guests are viewing this topic.
TheoriaApophasis
Quote from: gravityblock on July 22, 2014, 06:27:59 AM
Centripetal means the charges are flowing from the rim to the axis.  Centrifugal means the charges are flowing from the axis towards the rim. Feel free to replace 'rim' with the 'center point between the two poles' if you like.
Gravock
Clueless as heck.      SERIOUSLY,  how old are you?
100%  I#$&$($%  WRONG
NO SON,   magnetic  CENTRIPETAL magnetism LEFT from the other side.. leaving the centrifugal,  going ROUND to the other side  AT HEIGHT and speeding UP to the centripetal point at the middle
A TORNADO is centripetal son, it STARTS at the clouds and its speed increases AT THE GROUND POINT (surface of the magnet at dead center)
A BULLWHIP is a type of CENTRIFUGAL,  slow movement at hand, and breaking the sound barrier at the END of the whip.
YELLOW LINES BELOW ARE CENTRIFUGAL........GOING AROUND TO THE OTHER SIDE, RETURNING AT CENTER, CENTRIPETALLY, RED ARROWS
You are either PLAYING with me, or genuinely JUST THAT DUMB
See pic below son, THAT is a magnet,   the RED is centripetal , its the END RESULT of the other sides CENTRIFUGAL
thats why its called "magnetic reciprocation"  son.
Even a *@#&&@  Gaussmeter will tell you the HIGH GAUSS rating (magnetic velocity) at the EDGE of any magnet is THE HIGHEST
also very high at the dead center.
You said::::::
What the FUCKING HELL??????      Too bad magnetism is POLARIZED = SPATIAL..........   Magnetism is NOT moving just ALONG the surface of "each pole"  ;D  ;D  ;D , but GOING ROUND , GOING OUT (centrifugal)  and returning to the other side and entering the dead center (CENTRIPETAL)
Two options:
1. Extreme stupidity
2. playing games.
Either 1 or 2 does NOT bode well .
gravityblock
Quote from: TheoriaApophasis on July 22, 2014, 06:32:39 AM
100%  I#$&$($%  WRONG
You said::::::
What the FUCKING HELL? ??? ??      Too bad magnetism is POLARIZED = SPATIAL..........   Magnetism is NOT moving just ALONG the surface of "each pole"  ;D ;D ;D , but GOING ROUND , GOING OUT (centrifugal)  and returning to the other side and entering the dead center (CENTRIPETAL)
Two options:
2. playing games.
You sure do like to muddy the waters.  Your rebuttal has nothing to do with what I said, lol.
Gravock
TheoriaApophasis
Quote from: gravityblock on July 22, 2014, 06:38:53 AM
Gravock
Listen son, I dont mind ignorance,  EVERYONE is ignorant.
I don't know how to build a car motor, OR fix the goddamn thing   OK??
Just dont act like you know what the goddamn hell you're talking about on this subject.
Ignorance is good (if you know you have it).......  Being ignorant and thinking you AREN'T (about X), thats the pits of Hell itself.
My rebuttal was logical, and I can demonstrate same 1000 ways to Sunday, even 10$ bottle of FERROFLUID will show you this simple damn fact.
Wise up.
I suspect you're some teenager punk.    Typically such hubris is only found out of 2 people:
1. Old demented fools
2. Teenanger  know it all scum
And I doubt you are OLD
tinman
Quote from: picowatt on July 22, 2014, 06:31:34 AM
Tinman,
Interesting video.  But again, we still have current flow in the presence of a magnetic field, so it is not unreasonable to expect spin.  Can you tell if the torque is reduced with the tape applied (possibly via spin up rate)?  As well, does the spin rate vary with the applied current?
I am more so interested in the bubble vortex difference when using the PM versus EM.  Now that we know that a spin still appears with the neo's sides taped it will be easier to do tests with the EM.  Although the taped neo produced a somewhat different vortex appearance, with smaller multiple vortices, it is possible that these represent something closer to truth that may actually have been masked by the larger overall spin produced via the side torque.  It must also be kept in mind, however, that we still have current flow in the presence of an electrical field, so it is not at all unrealistic to expect spin generation via conventional means.  However, one would also expect a similar result from an electromagnet.
Therefore, a first experiment regarding the EM that might be considered is to modify the core of the EM so that its cross section is similar to the neo, particularly with regard to the poles, and repeat the test.  Was your EM core tubular?  Consider changing the core to a solid one or insert something into the tubular core to make the EM poles more similar to the neo.  Also, it would be wise to use a spring scale or a lift test to determine the current needed to make the EM similar to the PM in strength.  But again, the core cross section should be made similar to the neo before doing so.  Also, make sure the EM coil is electrically isolated from the electrolyte so as not to influence the current path.
Appreciate your time,
PW
Some answers i can give you already PW. The electromagnets cross section is the same as the neo's im using-as seen in a couple of the video's. Also in a couple of the video's,i use a cylinder magnet (hole through the middle) with the same cross section size as the EM's core. The neo still produces the vortex ,but as seen,the electromagnet dose not. The EM's coil power is totally isolated from the power supply. Even when using the battery charger(that has no common ground)to keep the battery voltage up,it is also isolated via the step down transformer-which dosnt have a common neutral(Primary and secondary are two sepperate winding's).
I need to say this once again,as some still dont get it.
I am stating facts on tests i carried out !!AND!! showed on video, on !!MY!! EM-not ruddy Johno's down the road. These are the results of !!MY!! DUT,not some other device. Other EM's may indeed give different results,and so they ruddy well should-because there !!NOT!! the same device.If you want the horse power rating of your mini clubman,do you put a ford mustang on the dyno to get it?. So,i stand by what i said-the EM (my EM) tested in the video,did NOT show the spin effect like the PM did-as seen in the video. So when i said the EM's field seems to be different to that of the PM's field,i was 100% correct-as seen in the video.
TheoriaApophasis
Quote from: tinman on July 22, 2014, 07:08:07 AM
The only reductive conclusion one can draw from all the pissing and moaning about your EM experiment is:
1. Theyre pissed that the vortex (fact) premise of PM is true, and (of course) not found in an EM
2. No matter WHAT you do, someone is going to say (just a few) you jacked the experiment (which you didnt, of course)
3. Theyre pissed that you proved a premise of mine with genuine experimentation.,........since they all generally seem to love you, but despise me........  As such, they're pissed your HONEST and unbiased experiments produced results in favor of my premise, and they really arent ticked at anything YOU did, but that it supports my position.
I hope you invent something WONDERFUL and make a LOAD of $$$$ so you and the fam can retire and tell the regular job to SHOVE IT  ;)  ;D  ;)  ;)
