Ultimate proof of Magnetic Vortex, free book and videos
Started by TheoriaApophasis, July 13, 2014, 04:20:12 AM
minnie
joel321
QuoteBut right now I have managed to work out my fuzz box hahahha Its very simple ! This fuzz box can create a void where mass can sit with out gravity and also make the mass invisible ...... !
It is a 1 metre length of coil made up of 12 coils which are in chromatic order by the natural resonance at 0 c temp ... It sits on a plastic pipe at 2.2 inch diameter as that is in square to the fabric of space time at 2.2 degrees imperial measurement ...
The magic coil has a saddle that it sits above at only 4 cm and made of silver and nickel  ! And a 168 000 v Polarised AC charge is delivered to the magic coil at a wave height at 10% the size of negative hydrogen ! I am not to sure what that is in HZ ? But I believe it to be 36000 HZ what is inversely square to the distance of earths gravitational field at 36000 miles ...
The device is at 36 inches off the ground and the pules delivery is set out along the logarithm of the 9 and as you lift off the ground you will need to change the pulse at every interval along the gravity field of the earth ... Earths gravity waves are set along the same path of the logarithm of the 9 over its 36000 mile distance starting at 36 inches !!!
When you switch it on a long length of sparks will appear along the coil and from the central point of the coil you will need a wire attached to the craft or mass and it must be sent to a negative charged coil as an independent new earth .............. !!!
These are the true and correct parameters to zero G for any mass at 36 inches off the ground ..!!! It is wise to insulate your craft if you wish to live in side of it or your body will be fuzzed out like the Philadelphia rainbow experiment and you will merge with the mass of the craft ............ !!!
This guy is entertainment lol Show it, don't say it. You can say that you are the queen of England till you are blue in the face, but you look like a hobo? (keeps on eating pop-corn hehehe)
Sounds like your mom/dad never slaped you in the face when you where telling little kid stories like when you told them that an eagle took you off your feet and to the nest, to then you beat the eagle to death and you made it home safely and alive?  ???
minnie
I was expecting some good advice from Joel on sharpening combs
and cutters.
    He could have explained about cloths,glue,disc pressure plates,
pendulums,magnetic holders,polishing compound,cleaning sticks,
and most importantly hollow grinding.
joel321
^ lol You are funny....you showed me a picture of a grinding wheel when I asked you how to sharped clippers. lol
You need to give me advice not the other way around...hehehehe If you want advice from me to save some money in your pockets, you need to pay me to show you my skills of sharpening the clippers and maintaining them sharp... trust me (they call me rat rotini) I can sharpen your clippers way sharp than they are right now...but not for freee...:)
