4-Plate Capacitor
Started by ibpointless2, July 14, 2014, 02:53:37 PM
ibpointless2
I would like to hear what you guys think about this...http://youtu.be/oMbSxXGOqSU
So I take 4 plates and separate them by a dielectric. I label each plate A through D, with plate A on the bottom and plate D on the top. I connect a battery to plate A and D and a meter to plates B and C. If I connect the battery I get a positive voltage that shows up on the meter that is connected to plates B and C. If I short out the plates A and D a negative but equal voltage shows up on plates B and C. So when I charge plates A and D from 0 volts to the VCC the B and C plates must start at VCC and go down to 0 volts as A and D get to VCC. When I short out A and D where they go from VCC to 0 volts the plates B and C go -VCC to 0 volts. [/font]
SchubertReijiMaigo
Interesting, I wonder what happen when your charge AD remove battery discharge BC and what is left to AD.
Then, measuring capacitance and voltage will get you energy with this Eq: 1/2*C*V^2
Comparing energy input vs ouput at each cycle of charge/discharge and plate.
ibpointless2
Lighting 3 LED's with the 4 plate capacitor... http://youtu.be/HPYru-yeId0
I get 3 flashes from LED's from one charge.
The brightness of the flashes is determined by the distance of the plates and not voltage.
The two LED's are connected so that they have opposite polarity so that you can see that the electricity goes both ways depending if your charging or discharging.
ALVARO_CS
hello ib
may be you find this interesting:  http://jnaudin.free.fr/cstack/index.htm
I made one of these with 4 strips of aluminium duct tape tight rolled. (support paper oiled as dielectric)
My intention was to use it as a kind of isolation transformer for the output from an Adams type motogen.
Interesting results.
ibpointless2
Quote from: ALVARO_CS on July 18, 2014, 05:23:54 AM
hello ib
Thank you for the link, it was a good read. Its interesting how we all come from different places but end up on the same page.
What happen to Cris Paltenghe? did he ever continue working on it? It looks like this webpage is from 2001, did he make any advancements? From the write up it looks like he only used AC, I wonder if he ever did DC like a I did and seen the same effect? So many new questions. [/size]
