Overunity electrolysis - 31 times more effective gas production than with DC
Started by hartiberlin, July 30, 2014, 08:22:30 AM
MarkE
Your nine slide presentation doesn't actually offer any explanations or new understandings.
Slide 1 Title
Slide 2 Table of Contents
Slide 3 Executive Summary:  People claim that water can be burned as a fuel, and the confused idea that burning water causes an implosion.  Oxidizing H2 gas with O2 gas implodes.
Slide 4.  Incorrect assertion that a machine that is externally powered is a free energy device.
Slide 5. Somewhat correct description of the gas volume reduction, IE implosion from oxidation of H2 gas with O2 gas.  Invalid assumption of infinite pressure volume source.  Invalid oversight of the fact that cycle by cycle the combustible feed stock has to push out the externally supplied gas that filled the implosion void.
Slide 6. Invalid claim that implosion volume is constant.  The volume depends on pressure and temperature.
Slide 7. Assertion of adiabatic expansion which runs counter to the earlier assumption of an infinite source.  Again neglects the volume that must be displaced back to the source in order to complete one cycle.
Slide 8. More of the discredited conspiracy theory that Stanley Meyer was murdered.  He suffered an aneurism.  Link to a different idea about electrolysis.  Link to discussion of the unestablished claims from the Indian report.
Slide 9. Claim that the silliness above is "Divine Revelation".
ltseung888
https://www.youtube.com/watch?v=bqlbb_ojAdI
Experimental comparison of implosion and explosion.
The first implosion was caused by HHO or Browns Gas.  Please examine the first few frames frame-by-frame as suggested.  The bag and the grass was shredded on the ground.  Surrounding air rushed in to cause the effect.  More comes from the top.  Listen to the sound carefully.
The second explosion was casused by HHO or Browns Gas mixed with water vapor.
With the addition of water vapor, the water vapor rapidly changed into steam.  The resulting steam (as gas) rapidly expands and causes the normal explosion behavior.
Can anyone dig up the old demonstration from Dennis Lee where he showed the lifting of weights using the implosion of Browns Gas?  Thank you.
ltseung888
Simple attempt to explain IMPLOSION working principle.  Practically no exhaust gas comes out!
MarkE
ltseung888
Quote from: MarkE on August 13, 2014, 05:22:18 AM
Lawrence, springs do not make working free energy machines.
We do not use springs.  We use the kinetic energy of air molecules.  We cool the environment.
God provides us with the Environmental Energy.  We must employ our Physics Knowledge to use it...
God also provides us with sunlight.  At one time, we did not know solar panels...
