Secret Of Back EMF
Started by TommeyLReed, August 12, 2014, 02:16:28 PM
tinman
Quote from: MarkE on August 15, 2014, 09:44:58 PM
As there is no specific DC current path provided for the winding energy, the capacitor charges up until something starts leaking badly.
I would say that the cap charges up until it has reached the maximum output of the flyback value.This is of course taking into account resistive lossed and the likes-unless that is what you are refering to MarkE as leakage ?. Of course there will be some leakage in the cap,and this can be seen as the voltage slowly dropping in the cap,if left sitting with a charge in it. This can also be seen as the internal resistance in the cap bleeding off the charge.
MarkE
Quote from: tinman on August 15, 2014, 10:15:05 PM
There is no maximum value until something breaks.  The magnetizing energy integrates on the capacitor until the voltage is high enough that the energy gets dissipated either through a resistance, or a clamping circuit, or leakage across the capacitor.  Many have designed circuits where flyback energy from a switched inductor broke things.  It's blown up a lot of John Rohner's controllers.
TommeyLReed
Many people just think they know the answers!
Inductive components like motor winding resist sudden changes in current. That's because the magnetic field caused by the current needs time to build up or decrease. That means that when current is flowing and this is suddenly cut off, the winding will try to maintain that current, and becomes a power source generating a voltage to be able to do so. It gets its power from the built up magnetic field.
Since the winding is now a power source instead of a consumer the voltage is reversed for the same current flow direction. That also explains how the voltage on a coil can become higher than the power supply: instead of subtracting the voltage over it you add it to the power supply. That's why you need a flyback diode on for instance a relay coil: the diode will allow the back emf to flow back to the power supply without damaging the switching transistor.
When a current flows through a conductor it generates a magnetic field around the conductor. with that being said in a solenoid the exact process take place, The magnetic fields around each turn on the coil link with the rest of the other fields on other turns to form complete loops around on the out side and the inner core of the coil. These line of flux will determine the polarity and strength of the solenoid. No matter how tight are the turns there will be flux lines that will always remain around each turn, these smaller flux lines will induce a current in the coil when there is an applied voltage(these currents that are induced are known as Eddy currents). But when these currents are induced they will be in a opposite direction with the applied current and since it is in a counter direction therefore it is known as the back EMF.
Counter-electromotive force
From Wikipedia, the free encyclopedia
Jump to: navigation, search
The counter-electromotive force also known as back electromotive force (abbreviated counter EMF, or CEMF)[1] is the voltage, or electromotive force, that pushes against the current which induces it. CEMF is the voltage drop in an alternating current (AC) circuit caused by magnetic induction (see Faraday's law of induction, electromagnetic induction, Lenz's Law). For example, the voltage drop across an inductor is due to the induced magnetic field inside the coil, and is equal to the current divided by the impedance of the inductor.[1][2] The voltage's polarity is at every moment the reverse of the input voltage.[1][3]
The term Back electromotive force, or just Back-EMF, is most commonly used to refer to the voltage that occurs in electric motors where there is relative motion between the armature of the motor and the magnetic field from the motor's field magnets, or windings. From Faraday's law, the voltage is proportional to the magnetic field, length of wire in the armature, and the speed of the motor. This effect is not due to the motor's inductance and is a completely separate effect.
In a motor using a rotating armature in the presence of a magnetic flux, the conductors cut the magnetic field lines as they rotate. This produces a voltage in the coil; the motor is acting like a generator (Faraday's law of induction.) at the same time it is a motor. This voltage opposes the original applied voltage; therefore, it is called "back-electromotive force" (by Lenz's law). With a lower overall voltage across the armature, the current flowing into the motor is reduced.[4] One practical application is to use this phenomenon to indirectly measure motor speed and position since the Back-EMF is proportional to the armature rotational speed.[5]
In motor control and robotics, the term "Back-EMF" often refers most specifically to actually using the voltage generated by a spinning motor to infer the speed of the motor's rotation for use in better controlling the motor in specific ways.[6]
To observe the effect of Back-EMF of a motor, one can perform this simple exercise. With an incandescent light on, cause a large motor such as a drill press, saw, air conditional compressor, or vacuum cleaner to start. The light may dim briefly as the motor starts. When the armature is not turning (called locked rotor) there is no Back-EMF and the motor's current draw is quite high. If the motor's starting current is high enough it will pull the line voltage down enough to notice the dimming of the light
https://www.youtube.com/watch?v=VfvfkXhHw04
I don't need to add any more, this says it all!
Tom
SeaMonkey
Quote from: TommeyLReed
Tom
That is the essence of the phenomenon.
Simple is best.
Except for the last sentence.
MarkE
Quote from: TommeyLReed on August 15, 2014, 11:39:48 PM
The field increases or decreases according to the time integral of applied voltage.
That is a close enough description for city music.
Correct, the voltage is whatever it takes to sustain the immediate current.
QuoteThat also explains how the voltage on a coil can become higher than the power supply
That is also correct.
Quote: instead of subtracting the voltage over it you add it to the power supply.
Polarity is determined by Lenz' Law.  The voltage rises or falls in such a way as to resist a change in current.
QuoteThat's why you need a flyback diode on for instance a relay coil: the diode will allow the back emf to flow back to the power supply without damaging the switching transistor.
A diode recirculates the current through the relay winding.
No it is the exact same thing.
QuoteThe magnetic fields around each turn on the coil link with the rest of the other fields on other turns to form complete loops around on the out side and the inner core of the coil. These line of flux will determine the polarity and strength of the solenoid. No matter how tight are the turns there will be flux lines that will always remain around each turn, these smaller flux lines will induce a current in the coil when there is an applied voltage(these currents that are induced are known as Eddy currents).
Eddy currents inside conductors give rise to the skin effect.
QuoteBut when these currents are induced they will be in a opposite direction with the applied current
Eddy currents induce voltage that opposes the driving voltage.  They are about resisting current changes.
Quoteand since it is in a counter direction therefore it is known as the back EMF.
That is correct.  BEMF resists changes in the current that any applied voltage attempts to drive.[quot]
In motor control and robotics, the term "Back-EMF" often refers most specifically to actually using the voltage generated by a spinning motor to infer the speed of the motor's rotation for use in better controlling the motor in specific ways.[6][/quote]That is the generator BEMF.
Tom
Yes it does.
