Thanks to ALL for your help!!
drawing energy from parallel realities
Started by Mancha, August 13, 2014, 06:23:15 AM
Mancha
to Void:
I have asked man from our team who made program for micro controller.
He told me that during 8440 nano seconds micro controller makes 10 measurements and gives out average value.
Beside that, let me remind you that we got very often charge gain with simple spark gap version which i described on video.
Also have been noticed strange effect that  sometimes we got sparks jumping across both spark gaps in the same time, but just one capacitor collected charge.
But we left this version, because  it was too slow and so violent discharge.
The violent discharge  is much better  to get this effect, but so difficult to measure properly, because time frame to do that is short.
If inductance will take place  here, when C1 or C2 will has 18V, then source capacitor will has 6V only, but this  has not been measured
On the end.... yeas we are ready to accept if we made some mistake in our approach and measurements.
All the best,
Milan
Mancha
I forgot to say that next voltage reading after 10 s also shows gain in charge, which tell us two things
1. the voltage is reading is correct (easy to check with digital voltmeter)
2. the  time frame for detection parallel reality ( and consume this charge gain) is running out
In some of our test  we did not have charge gain after 10 seconds
The time frame depends of total energy movement, capacity, initial voltage etc. Like in other fileds of classic physics.
All The Best,
Milan
Mancha
you can see my new video about very strange affect which I have noticed  in 2005.
http://youtu.be/GE5xUdoERtA
Here are short  footage which I was lucky to catch in 2011.
https://www.youtube.com/watch?v=4u2mBUZmXjA
All the Best,
Milan
gotoluc
Hello Milan,
thank you for presenting your experiments.
I was wondering what would happen to C1 test results if you replaced C2 with a 100 Ohm Resistor?... could you test this and report the results?
Thank you
Luc
Turbo
For ' Parallel reality ' you have to use Antimatter.
Positrons.
