Thanks to ALL for your help!!
Longitudinal Wave Experiment to demonstrate Overunity
Started by magpwr, August 16, 2014, 01:12:29 AM
Marsing
Quote from: poynt99 on August 17, 2014, 09:51:25 AM
Consider this (my estimate of output power):
Vpeak ~ 100V
Period T ~ 250us
Pulse width t ~ 200ns (assume nice rectangular pulse, even though it is closer to triangle)
Duty cycle D ~ 200ns/250us = 0.08%
Load = 1 Ohm
power = V2/R; 1002/1 = 10kW
now multiply by approximate duty cycle factor of 0.0008, and you have 8W average output power.
Based on this (unless I've made an error somewhere), it seems 98W estimated output power is very optimistic.
hi poynt99
where is T 250us come from and why?  i saw 4khz is input frek.
then 3% from 33 watt input := 0,99 watt average input is very good for 8W output. :)
sorry if i made any error, just quick count.
poynt99
Quote from: magpwr on August 17, 2014, 11:08:00 AM
hi poynt99,
May i ask how do you explain the 250watt x 3 bulb filament got destroyed intentionally at higher input voltage and create spike higher than 180volts which would destroy the filaments.Please produce your version of explanation which i would like to hear.This part i'm at a lost on how to explain myself. :D
I looked for your video of that but was unable to find it.
Anyway, if you are generating a substantial inductive kickback on the load side of the circuit, it is possible to knock out the filaments from the same effect seen when a regular incandescent 100W bulb gets "burned out" simply from switching the light on. It can conduct a significant current when cold, and as such experience an electro-mechanical kick against the earth's magnetic field.
Another question i pose to you -Would a incandescent bulb produce blinking effect at high frequency anything more than 18hz .Anything more than that which our human eyes is unable to detect even for fast response led. :D
Not sure I understand your question, so I'll guess. I would say yes you could probably notice blinking or fading with a bulb driven at 18Hz.
A 1 ohm resistor capable of handling 100 Watts is no small thing, and will become quite hot while doing it. You probably would not be able to hold it in your fingers. Think of how hot a 100 Watt lightbulb gets when actually running on mains power.
d3x0r
Is there a way to measure ESR of a capacitor?
It appears that these high voltage ceramic caps I have are low ESR
I ordered them from http://hvstuff.com/high-voltage-capacitors/ceramic/disc
Dissipation Factor   ≤0.01
found a quote somewhere... "(Ceramics have lower ESR than tantalum or aluminum electrolytics.)"
so... should be good, right?
poynt99
Quote from: Marsing on August 17, 2014, 12:00:07 PM
hi poynt99
See the attached scope shot. Scale is set to 1ms/DIV, so there is roughly 250us between pulses.
...and also 1/4kHz is 250us, right?
I wouldn't count on that 33W figure as being accurate. I haven't seen an explanation as to how he got that figure.
