New Scalar Wave Detector and laws of Scalar Physics
Started by wdjensen123, September 21, 2014, 09:28:35 PM
AlienGrey
Quote from: TinselKoala on March 05, 2018, 05:33:51 PM
Nice bit of carpentry, did you do a constructional video by any chance, nice work any way.
AG|
SolarLab
Type of wave?
Been a few years since we did this stuff but:
Working in the large RF Shield room (still a sweat box) we tried horizontal, vertical, and a variety
of polarization blocking test - no noticeable power (signal) perturbations or degradation.
Conclusion - not transversal, therefore surmised it had to be something else (rocket science at it's finest).  :)
A complete Faraday cover (6 sides solid copper and aluminum, sealed edges)
- slight loss of power but we couldn't get inside the box to monitor the input. Center ground rod to earth,
other grounding to cage edges via heavy welding cable. Surmised, had to be electric only.
But, by carefully moving the two receivers into a line-of-sight configuration with the transmitter and varying
the distance between the receivers there were spots where the power appeared to vary, not a lot, probably
less than a dB or so therefore we surmised longitudinal with wave interference. Not conclusive by any means
but we figured it was a good guess at the time; and since some accept the notion of a longitudinal type wave,
and we didn't have any other means or ideas of testing it; we left it at that.
However, it would seem logical that if the magnetic part of a transverse wave is removed, or doesn't exist, the
waveform would likely be longitudinal. By definition I'm not sure what else it might be.
I think this effect appears in magnetics as well.
Smokey <=> And to be clear, we are dealing with spherical waves.
Not "longitudinal" waves.
Your likely correct that the device has a Spherical radiation pattern as it's antenna is absolutely non-directional.
Actually I've never seen a "spherical waveform," however, if you watch the smoke from a cigarette in the sunlight on a
calm day it moves in tiny, almost spherical, vortex patterns; so there may be something to it. Might explain some of
the bazaar characteristic propagation behavior we're seeing. I'm certainly open to discovering more.
Well, let me back up a bit - Ball Lightning might be evidence of a spherical wave, of sorts, and it's inter-related to HV.
The apparatus is packed away but I'm setting up a new "my private" corner in the lab so maybe?
That's right.
https://www.youtube.com/watch?v=i-MA8rzZSqk
(Sorry about the light...)
However.... there are Faraday cages, and then there are Faraday cages. It takes a _lot_ of effort to make a good one. What I used in the above video isn't a particularly good one but does effectively shield low frequency RF.
The Caduceus antenna shown in the video does produce a tightly directional beam and is supposed to work by just that kind of cancellation or attenuation of the M part of the EM wave that is referred to by SolarLab above.
Quote from: AlienGrey on March 05, 2018, 06:25:49 PM
AG|
Thanks, no construction video but there will be some demonstration videos coming up in the next few days.
blueplanet
I think your observation makes more sense to me.
Quote from: conradelektro on March 05, 2018, 12:56:10 PM
I did the same experiment as in the videos "successfully". But what tells you that you experienced longitudinal or scalar waves? There is a difference to your "successful" experiment, I did not make a video. Maybe it needs the recording of a video to show longitudinal or scalar waves. I guess it is the words uttered in the video which exhibit the longitudinal or scalar waves.
The attached photo shows the function generator and the oscilloscope used, the pancake coils and the air capacitor. One does not need pancake coils it also "works" with ordinary coils.
Greetings, Conrad
