Thanks to ALL for your help!!
New Scalar Wave Detector and laws of Scalar Physics
Started by wdjensen123, September 21, 2014, 09:28:35 PM
sm0ky2
the nonsensical "scalar math" being propagated is a manipulation of Maxwell's equations
most of which misappropriate the use of time.
none of them show anything resembling a scalar wave
they are simply pulling apart the equation and substituting terms so support their ideas.
we already have electromagnetic theory that describes anything they are doing with it.
and does so appropriately
as far as the faraday cages go
there is really only one important ratio
that is: wavelength : aperture
that alone determines most of what passes through
(thickness is another parameter)
The next set of frequencies are partial waves, that have been interfered with, but not wholly absorbed by the cage
and are of lower magnitude (v*i/t)
and a 3rd, 4th, 5th set and do on, each next set being of lower magnitude
Which set your frequency falls in , determine how the energy passes through
a fine chain-mesh can block microwaves,
but in theory Thz waves will pass through in full
and lower sets will pass through in part
an minimal wavelength theorized by Max Plank would be difficult to block.
but if done, you would have an "ideal Faraday Cage"
There are also nodal-exceptions
where-in, certain ratios allow longer wavelength to pass through in part,
or cause a frequency doubling effect as they pass through (wave-splitting)
By the same equations we can design a faraday cage that
blocks a specific frequency (others will pass through according to their ratio)
this is seen in your microwave oven
the aperture size is specifically designed
to block 100% of the 0.1223643 m wavelength
and most of it's harmonics
this keeps your food hot and you not
The inverse occurs in the magnetron, it only allows 2.45Ghz to escape
a cage that blocks RF, you might be able to make a phone call in
cages are generally designed for the application
some applications are more lenient of the parameters
sm0ky2
sm0ky2
Two waves sent to interference with one another and cause cancelation
However, there can still be a change in potential at the point of interference
This change in potential is recognized as a possible causality
This vectorless scalar amplitude propagates from the target location
the propagation then takes on a vector (spherical if undisturbed)
this can produce the scalar event
and demonstrate some of the effects
in this manner (a much more complex than shown) scalar interferometer
can be produced
sm0ky2
The actual event, is from the change in localized potential
not from the electromagnetic signals
This distinction is important
If we are to understand what the scalar wave actually is
Belfior
can you tell me one good reason not to call Bearden just a cheat and just trying to make some money? One good reason will do.
