Magnet Myths and Misconceptions
Started by hartiberlin, September 27, 2014, 05:54:29 PM
EMJunkie
Quote from: MarkE on January 14, 2015, 07:10:58 PM
Bill Alek's  device does not work as he claims.  It is nothing more than a transformer with lots of leakage inductance.  Bad measurements lead out dumb conclusions.  If Bill Alek wants to reach a conclusion he need only rent or buy a pair of power analyzers.  He can then configure as he does in his demonstrations where he thinks that the load drives the source and reconcile that with the fact that he hasn't been able to make any device generate net surplus power.
MarkE - I have noted your Opinion!
EMJunkie
@ALL
Think Magnetic Oscillator!
Like the Hydraulic Ram Pump is a Gravitic Oscillator! 300+ years of history behind this device!
Kind Regards
   Chris Sykes - hyiq.org
   To Reach New Horizons!
EMJunkie
@ALL - Again I ask:
"Electricity is not made by the generator, it is merely captured or pumped."
Why? How? Ask Questions!!!
Kind Regards
EMJunkie
@ALL - Another quote from another brilliant mind:
"This resulted in a current gain in the secondary, relative to the primary. Lenz's law was bypassed, and free-energy resulted. An alternate explanation for the current gain in the UDT is to consider each secondary winding as acting as the primary winding for the other secondary winding when an output current is drawn because the two secondary windings generate geometrically opposing fields."
URL: http://www.hyiq.org/Research/Details?Name=A%20Free-Energy%20Device
The above document is perhaps the best read in all of the Energy Field!
Again: "we can see that when the Transformer is loaded, there is a NET ZERO Magnetic Field. This means the Ampere Turns on the primary are equal but opposite to the Ampere Turns on the secondary, or close to it. Where the Vector of each Magnetic Field sum's to ZERO!!!"
Please start asking questions, in your mind, Why?
Kind Regards
Quote"The generators that now furnish our electric power do not create or originate any power or electricity; they merely direct "pump" the existing energy or electricity."
They convert brute force mechanical power into brute force electrical power.  They are simply transformers.  If you take the water analogy, the electric field generated in the output coil could be viewed as a pressure pump.  As you travel along the length of the coil you are going up in potential (pressure) due to the 'pushing' electric field inside the coil.  In other words, as you walk along the electric field inside the wire you go up in potential.
For the bucking coils clip, someone could do that test without too much difficulty.  You could measure the AC power going though the primary and secondary quite easily.  A signal generator and an audio amp and a few multimeters and a big fat 8-ohm resistor and a variable load resistor and some odds and ends and you would be able to see what was going on.  The results will be as expected.
