Magnet Myths and Misconceptions
Started by hartiberlin, September 27, 2014, 05:54:29 PM
MarkE
Quote from: itsu on January 10, 2015, 06:36:16 PM
Ok,  wide part of the magnet stack scanned, sensor fixed from above, sliding the magnet stack underneath it (1cm)
https://www.youtube.com/watch?v=n-5WxjH8IqM&feature=youtu.be
Regards Itsu
Yep, that is as should be expected.
tinman
Quote from: MarkE on January 10, 2015, 06:30:19 PM
Your depiction is absolutely wrong.
My depiction is correct in regards to the useful magnetic field. This i have said time and time again.
Both Itsu and AC have shown this to be true with your very own test.
Like i said before Mark,you are including your !field of dreams! into the picture.
tinman
Quote from: allcanadian on January 10, 2015, 06:17:33 PM
@tinman
If we were to plot the "difference" between the center zero plane between the two poles and the looped conventional paths then yes I believe it very well may follow the line you have depicted. To be honest I never thought of that until I saw your diagram.
There are points where the parallel and perpendicular measures from the hall sensor appear equal within the field where the two planes intersect.
I should be able to add another sensor at 90 degrees and plot a second graph with labview. Then a third graph showing the difference between the two and follow the line.
AC
I will be looking forward to that AC.
MarkE
Quote from: tinman on January 10, 2015, 06:54:45 PM
Thank you Itsu,TK and AC for doing these test. Different results from TK to that of Itsu and AC,so where dose that leave us?
TK's parallel facing tests agree with:  theory Itus's tests and my own.  Itsu's perpendicular tests agree with theory and my own experiments with ceramic and ferrite magnets.
TK's perpendicular facing tests with nearly uniform readings may have saturated the sensor amplifier.  That would have been particularly likely if his magnets are very strong.
Pirate88179
Quote from: MarkE on January 10, 2015, 07:29:23 PM
I believe TK said in one/both videos that his little magnets were N52, which is very strong.  I have mostly N40 (or thereabouts) here and they are incredibly strong.  I was surprised to see that they did not mess with his meter.
