Nuclear Resonat Battery test soon to come
Started by pomodoro, September 28, 2014, 08:06:59 AM
profitis
Then what is boosting power pomodoro? Resonant up-conversion against 2nd law? Its been known to happen with far-infrared.question is,what was moray up-converting?
pomodoro
Those tubes in his patent are interesting. They supposedly protected the power supply by shorting out at a high voltage. But in reality much simpler systems would have been used instead. In fact the power supply or transformer can easily be designed so as not to require external protection. One tube was reported as having a capacitance of 1F! This was a massive value only a few years ago, let alone in the 50s.  Perhaps those tubes oscillated in a tank circuit and produced power?
Let's see what happens when I zap the uranium salt in a 1uH high Q copper foil coil with a 0.25uF cap charged at 8000v
profitis
It also helps to note that bismuth on exposure to neutrons from uranium turns into polonium,potent alpha emitter.
Kator01
@profits: "We have to get to the basics first"
thats exactly what is foremost necessary. Was one of the reasons why I presented the two links because there is shown one principle
of Betavoltaic so we do not have to speculate about devices which we will not know how they really functioned because of obvious reasons.
I repeat: "is shown one priciple" I know another one which in fact is much more interesting because it opens a total new view into what is going on during readioactive decay and how this decay-process can be trapped while the radioactive element repeats to decay but is hindered by some Parameter thus leading to a phaenomenon called "fermi-resonance".
The links to these vids were also presented by wesley but I have to confess that I will have to study this more than one time to understand the underlying principle.
@profits: unfortunately most of this is presented in intorductory vids
Here is the main website of Snake River N-Radiation Lab
http://www.srnrl.com/
lets have a closer look at what Paul Brown is saying and I wonder why many do not either read or understand what is written in plain language
"a single beta particle emitted from strontium-90 that is absorbed in copper will generate 80,000 ions in a distance of .030 inches."
So here we have it: this is how you can create sort of a supracoductor
futher:
" This increase in the number of moving charge carriers is measured in the real world as increased current.
We also measure a reduction in the resistance of the wire and an increase in its conductivity while the current is directly proportional to the voltage. In other words, the current goes up with an increase of the voltage" !!!
Did you read the curriculum vitae of P.Brown at the last page of the second link ?
I would have put this curriculum at the beginning of this document to make it clear who is presenting this knowledge.
Kator01
[/font]
pomodoro
The probability of spontaneous fission of U238 and U235 are way too low. Way below 1  in a million per decay. The only chance is if strong alternating ac field can speed things up. This has never been shown to happen, although the spin of unpaired protons can be , such as with NMR.
