Nuclear Resonat Battery test soon to come
Started by pomodoro, September 28, 2014, 08:06:59 AM
pomodoro
There is no difference. I'm going to charge the cap to a few thousand volts and discharge it through the coil next, to see if a strong magnetic field is required. If that doesn't give a tiny improvement in the Q then my personal conclusion is that Brown probably never had a working version either.
profitis
You can't say that for certain pomodoro.Brown used beryllium in his alloy thus it must be important.neutrons are the one thing that will interact with just about any matter wether slow or fast.mix a beryllium salt with your uranium salt and see what happens.neutrons penetrate.alphas dont
pomodoro
Not true profitis. Brown's patent is about alpha sources only. He uses 1mg of radium, some powdered thorium in a cardboard box!! and uranium rods. The powdered thorium burns in air but never mind that slip up. A year later, at a convention he forgets completely about this incredible 9kw invention and discusses the beta battery you mention. The beta battery is much weaker in power. No development of the patent battery is ever mentioned again. Money from investors comes in but a working model is never shown. Sorry but it smells fishy to me. Moray is far more credible.
profitis
I don't think moray is any more or less credible than the next,we can only speculate until we hit on the facts.let's go back to basics: moray had uranium metal,bismuth,and a string of semiconductors shoved in a tube.he also had some sort of arial attatched to this conglomerate.what was going on in that tube? Semi-conductors job is to rectify,rectify what? Bismuths job is an neutron shield and alpha source post bombardment,alpha source post bombardment..alpha source post bombardment..
profitis
You should be meausuring the uranium's geiger activity while pulsing it with electromagetism pomodoro.you might not register a change in the coils capacitance but you might register a change in geiger activity
