Sum of torque
Started by EOW, October 12, 2014, 05:36:02 AM
EOW
QuoteFurthermore, you also got to extract the power from the generator to measure it ...
It's easy with brushes and a plate with paths of copper, it's possible to use 2 brushes for input and 2 brushes for output. The main problem is to find a motor with a good efficiency.
dieter
Hard enough to find high efficiency dc motors, let alone low RPM without gears... ebay has only high RPM, down to 3600 RPM, as far as I see.
BR
EOW
Hi Dieter,
Maybe I can use a stepping motor with a big difference of radius like that I can use a dc motor for the generator. I will look for the efficiency of the stepping motor.
DreamThinkBuild
Hi EOW,
Here is a patent that you may find interesting, it's in French but he gives examples in the drawings on how to match input motor, to gear reduction, to generator rating. He's using servo motors.
EOW
Hi DreamThinkBuild,
I speak french, so it's easy for me. Thanks but there is an error in the patent and there is no rotationnal support.
