Sum of torque
Started by EOW, October 12, 2014, 05:36:02 AM
EOW
It's only a motor, 2 disks on a support. The motor give a counterclockwise torque on 2 disks, so the support receives a clockwise torque. There is friction between 2 disks at point A and B. If 'd' is very small all the counterclockwise torque on the support can be canceled. Like the support is turning clockwise at w1, it's possible to recover energy from the support because w1 can be very high, in the contrary the energy needed for give friction is very small (local angular velocity not dependant of w1).
The motor gives: -F1 to the red disk and -F2 to the magenta disk. The motor receives F1 and F2.
The red disk gives to the magenta disk F3, the red disk receives -F3
The magenta disk gives to the red disk F4, the magenta disk receives -F4
Axis of rotation of the magenta disk is on the support. Axis of rotation of the motor is on the support. When all disks are turning they are like the image all the time.
EOW
Look at the image. The support receives a clockwise torque Fd. Each disk receives a torque equal at 0. The motor give energy to friction but if the support is turning very quickly the energy won is high.
EOW
With one motor it could be ok.
EOW
Maybe like this ?
The support is turning clockwise at w1, it receives a clockwise torque from 3 motors. There is no counterclockwise torque from pulleys or belts on the support. w1 can be very high. The energy gave by motors is lost but the energy gave to the electromagnetic devices can be recover.
I need only special belts that can push only, or push only or push and pull. I drawn 6 pulleys but it can be 100.
EOW
