Quanta Magnetics Experimental Kits
Started by Scorch, October 15, 2014, 02:06:58 PM
Pirate88179
Quote from: MarkE on October 20, 2014, 10:51:07 PM
Are you sure that works?  Does it hold for large values of two and small values of four?
I don't know, I have not added this myself yet.  I'll give it a go in the next few weeks and let you know.
TK:
QuoteYou are referring to this Quanta "high voltage" clip, showing "600% AMPLIFIED VOLTAGE" (caps in original) ??
Yes, that's the clip.  Polycarbonate Perspex Lucite toroid awesomeness!
I watched your new clip.  MHOP lives!  It's a wonder that no Bedini-ites have defected from the Yahoo cult and tried it out.  Perhaps they meet in secret and operate in MHOP cells and they use the 'dark' portion of the Internet.   8)
@MH:  Yep, it was neat to be able to pull it down off the shelf, dust it off, hook it up and have it start immediately. It took me a minute to remember all the switch options. There are 4 switches, not including the simple power-on-off switch. I can switch the coil polarity, so that it can be either a pure attraction or a pure repulsion PM. I can switch the power takeoff from recirculating, or none, or output without recirculating. I can turn the strobes on or off, and choose whether to look at the "timing" strobe or the "dwell" strobe (beginning or end of pulse). The rotor can be removed in seconds and the sense coil repositioned easily to make the "rotorless" version, which also charges caps and batteries well, without wasting power turning a rotor/fan. The power mosfet is in a socket so it can be easily swapped, and a larger rotor with more magnets can be fitted by adjusting the coil positions. The two recirculation neons actually feed into opposite poles of the battery, so I could say that I am pulse-charging both the negative and the positive side of the run battery (how's that for woo!)
nelsonrochaa
Hi, i post the link for this video https://www.youtube.com/watch?v=F7EkHm08Te4
with no electronic commutation . :)
Quote from: nelsonrochaa on October 21, 2014, 05:06:27 PM
What's the difference between "oscillation" and "electronic commutation"?
