The new generator no effect counter B. EMF part 2 ( Selfrunning )
Started by syairchairun, November 09, 2014, 09:05:00 AM
thngr
This is the WORD than: Try not hard but simple and steady. There is no hard problem but complex ones are.
FatBird
Here is a generator that turns freely.
http://www.youtube.com/watch?v=vFfsEfnsA4I
Jimboot
Quote from: T-1000 on December 01, 2014, 05:49:34 PM
If to think in E. Leedskalnin terms my design is all OK. You have deflection force caused by magnetic flux increase in coil when iron bar approaches then you have magnetic flux decrease when iron bar shorts 2 magnetic poles of magnets (so you have attraction force from coil when iron bar is already under coil) and the in the last step when iron bar is moving away from coil you get opposite magnetic flux increase with deflection force. So the net Lenz force = 0 in iron bar movement around circle when you sum it up. Balance magnetic forces around circle and then have 0 physical reaction even in strongest magnetic coupling between magnets and shorted coil. :) Then unbalance deflection force from coil and make it stronger when iron bar goes away from coil and you get generator+motor in single coil...
I need pictures to understand what is happening. I know the bemf is not causing the motor to draw any more power, or at least what I have measured so far. . What I don't quite understand is what is happening with the fields to cause the current. Is theoria still on [size=78%]The forum? I'd love his input as well. [/size]
FatBird
Car Runs On SELF RUNNING Generator Only.  No engine, No Transmission, and No Water Hydrogen.
