The new generator no effect counter B. EMF part 2 ( Selfrunning )
Started by syairchairun, November 09, 2014, 09:05:00 AM
Jimboot
Quote from: georgio78 on December 14, 2014, 07:28:23 AM
HEY GUYS I RECENTLY PURCHASED TWO ST 4 POLE AC SYNC GENERATORS EXACTLY
AS SYAIR SHOWED IN HIS LAST VIDEO ONE GEN WILL BE THE PERMANENT MAGNET 220 RPM ALREADY ORDERED MAGNETS AND STATOR IS GETTING REWOUND AS SYAIR STATED! AND FOR THE OTHER GEN I'M PUTTING TOGETHER THE 1500 RPM HAVING IRON LAMINATIONS CUT TO SIZE AS WE SPEAK AND ALSO MY MACHINIST HAS STARTED THE WORK FOR MACHINING OF END PLATES ETC IT WILL BE THE SAME AIR GAP AS FACTORY 0.5 BOTH ENDS! ALL THIS IS NOT GOING TO BE CHEAP BUT FUCK IT I'M TAKING A GAMBLE! I HAVE CURRENTLY ONLY ONE PIC OF THE IRON LAMINATIONS TAKEN FROM THE STANDARD 4 POLE GEN ALL THIS WILL BE READY AROUND END OF JAN SO WNOT POST ANYTHING TILL I'M DONE ALL THE BEST GUYS FOR THE FESTIVE SEASON AND GOOD LUCK!
That's fantastic mate! Well done.
Let me know if I can help.
Ps may want to take off the caps lock. :)
FatBird
stivep
To Arunas T1000:
As of yesterday I know, but I did not check the trick.
So fricken  easy.
I check it out and let you guys know.
There is enough  of BS,  confusing most of us, and I do not want to  add more of it on the top of the old one.
"" text modified"""
Wesley
Ps:
for security reason I say that
"I was told  that
("" text modified""") was building and experimenting  with - satellite  powering system based on it.
I do not know the identity  of that person  "
"They(""" text modified""")  test  it.
"They" test with their money our ideas
Can you believe it?
Surprisingly it lids to me  and  you my friend Arunas  - the  Lithuania Experiment
It touches and is connected by  presence of that yoke with
Akula,
SR,
Daly,
Ruslan
possibly  but not  for sure Tariel Kapanadze.
Everything is    ( "" text modified""" )                       connected and is the most close to
Transformer by Alexander Kugushov  and my experiment with Colman effect
(taken or  thought - as  together )
But no one from experimenters listed here knows what is really going on.
Yes they got  results  and they  do not understand it. That  is why Akula called Tiger for help.
And that is  why even Tiger can not repeat it.
We are cruising around the same phenomena - even this  plot with magnets is included in it
( but no  moving parts- just static arrangement)
T-1000
The https://www.youtube.com/watch?v=m5KcU2n8qnw - nice try Ufopolitics :)
Just the spinning iron is still on constant magnets source in that video effectively making permanent magnets in spinning iron blades and this is still a cause of the problem when coils are shorted.
If you can make them change source magnet twice when it is passing coil as it spins then the interesting thing will be there with effect we all are after...
Cheers!
