The new generator no effect counter B. EMF part 2 ( Selfrunning )
Started by syairchairun, November 09, 2014, 09:05:00 AM
Jimboot
No need to retract. I showed rms over 5ohm load but I don't think power in was on camera. I was just puzzled at your seemingly belligerent tone.
It's costing me around 4watts to get 400mw on a single coil with a two pole rotor. Not 65watts to get the same.
Just because you are not getting good results from your design doesn't mean others aren't.
gotoluc
I use the drill press for convenience. The input power does not matter as long as you can measure it and detect a small change.
If I would of measured no change to the prime mover when the coil was under load I would take the time to build a new efficient prime mover.
However, it has not been the case. All tests are basic generator action.
I have taken the time to share my results to help others who may be sitting on the fence waiting for results instead of just walking away like many do.
Luc
gotoluc
I will be sharing my replication attempt of Erfinder's multi strand bucking gen coils at this topic: http://www.overunityresearch.com/index.php?topic=2782.0
Jimboot
Quote from: gotoluc on February 04, 2015, 11:50:38 PM
Luc
No worries. In my tests I have found that to get 400mw in a traditional gen setup requires close to 8 watt off the same rotor coil and core which is one reason why Im still pursuing it. All the best
thngr
Quote from: Mister Caribbean Roots on January 31, 2015, 10:08:36 PM
Hi all,
Here's an update on the T1000 flux gate design... ;)
https://www.youtube.com/watch?v=DtWMullF4O0
More info in the video section and this is my last post here but i will continue on O.U.R forum... ;D
I don't have the time for more than 1 forum and this here...
Connection Problems
Sorry, SMF was unable to connect to the database. This may be caused by the server being busy. Please try again later.
really drive me nuts here...lol
Took me a few try outs just to mod this post... :(
Cheers
you have promissing results MC. but don't you think rator had to be upgraded?  Find some ferrite core peaces or rusty iron dust with a little bit resin molded(better cores we must have). and iron washers are not ferrite cores :D
