3rd working machine you gandmother could make _2nd Law crushed
Started by The Eskimo Quinn, November 26, 2014, 02:46:58 PM
akbill
Quote from: telecom on November 28, 2014, 12:06:40 PM
This is a French patent I was referring too:
http://vitanar.narod.ru/files/02830575A1.pdf
I would like to hear what you, guys, think about its viability.
Regards  This patent did work, It used gravity to change the displacement.  I tried a similar thing in 2000.  It worked all be it only to a depth of ten feet.  Now if You could alter the density of a solid and not be effected by pressure, that would be the answer.
The Eskimo Quinn
ANIMATION - central component
this is the section that makes the machine provide free energy, the full sequence of putting the block in the base of the tower, Have attached the full sequence list again i know it is painful to troll to find stuff, he has almost finished the full circuit run, but everyone knows stuff floats and the falling weight part. will post that one  when done, Look like it really will be the perfect Christmas
click on pre render avi
TMQ
My PROOF THAT DEMOCRACY IS DEAD AND THAT WE MUST ATTACK AND KILL THE NAZIS IS RIGHT IN FRONT OF YOU, THE U.S, aUSTRALIAN AND BRITSIH GOVERNMENTS ARE THE OPPOSITION PARTIES TO THE ORIGINAL INVADING GOVERNMENTS, DEMOCRACY DIDN'T WORK, BOTH MAINSTREAM PARTIES ARE NAZIS, DEATH TO THE NAZIS, DEATH TO ALL SYMPATHIZERS AND SUPPORTERS http://www.youtube.com/watch?v=39c-kpgDY58&feature=related
The Eskimo Quinn
When i log in ther is usually one of the last replies up, i nearly died laughing when i read the webby response, what lower float he is talking about i have no idea, how it would push the weight down and out through a 50 ton ram is beyond me, oh, an i was wonder how many divers got pushed back into submarines after the pressure was equalized, or got pushed down and out back through the wall of the sub, clearly does not read instructions well, it has bee tested with floating weight blocks to several meters in water tanks, it rises faster, simply because the pressure difference increases, not decreases, and the gravity still stay as it always has at 9.81
Hilarious stuff, best call the submarine guys and tell them none of the airlocks work and divers can no longer go outside. It is 120 metres not the Marianas trench.
oh and to spare the forum your great science with some diver suit crap or crushing theories I have posted the pressure in the real world on a human with no gear at that depth. "NOTHING" I spose there may be ten ton marshmallow blocks????? HMMM yes i concede defeat to the ten ton marshmallow man, Webby
http://www.worldrecordacademy.com/sports/deepest_free_immersion_dive_world_record_set_by_William_Trubridge_101665.htm
Quote from: The Not So Mighty Quinnoh and to spare the forum your great science with some diver suit crap or crushing theories I have posted the pressure in the real world on a human with no gear at that depth. "NOTHING"
At 120 meters depth in a column of water the pressure is not "NOTHING". It is around 13 atmospheres, or about 190 pounds per square inch.
QuoteLike air, water causes pressure by its weight. But of course, water is considerably denser (i.e., heavier for a given volume) than air. As it turns out, a column of sea water one inch in cross-section would need to be only about 33 feet (10 meters) tall to weigh 14.7 pounds. Therefore, at a depth of 33 feet (10 meters) beneath the sea surface, the total ambient pressure is about 29.4 psi, or 2 ATM -- 1 ATM caused by the weight of the air in Earth's atmosphere, plus 1 ATM for the weight of 33 feet (10 meters) of seawater. To avoid confusion, when people discuss pressures underwater, the unit "ATA" (referring to "atmospheres absolute") is often used to represent the total, "absolute" pressure caused by both the water and the air above the water.
As is illustrated in the diagram at right, the ambient pressure increases underwater at an almost linear rate with increasing depth*. For every 33 feet (10 meters) of depth in sea water, the ambient pressure increases by an an additional 14.7 psi (1 atm). At a depth of 99 feet (30 meters), the ambient pressure is 4 ATA -- one ATM caused by the Earth's atmosphere, plus 3 ATM for every 33 feet (10 meters) of depth. Similarly, the ambient pressure 297 feet (90 meters) beneath the surface is 10 ATA.
http://www.bishopmuseum.org/research/treks/palautz97/phys.html
or hundreds of other references.
akbill
Quote from: TinselKoala on December 22, 2014, 08:50:50 AM
Quinn is most likely using His transporter and the source of energy is the dilithium crystals.
