OverUnity Does Not Exist!
Started by Nink, November 28, 2014, 09:23:20 AM
Nink
Quote from: rods on December 05, 2014, 06:08:01 AM
For those who are asking for videos and pics of my lever powered machine. I will try to post some over the next month or so.
Picture would be good, difficult to visualize from your description I tried to draw based on what you wrote but..... I am sure someone could build a small scale version and test if they had some photos..
DaS Energy
As yet untested in its final design, it appears OverUnity is possible.
The basis for this any turbine that is 82% efficient will convert one litre per second of 9 bar force flow into 720 watts, such known turbines being the Francis and Pelton. Either turbine receiving one litre per second at 9,000 bar force shall produce 720KW.
It is also known that Carbon Dioxide-CO2 rising in temperature from +30*C to +100*C has a pressure force exceeding 9,000 bar.
Carbon Dioxide- CO2 at temperatures becomes a Supercritical fluid, IE a gas behaving as if its liquid.
It is known that Carbon Dioxide-CO2 passaging through water shall take on the waters temperature.
To heat one litre of water by +100C in one second requires 456KW, or 0.076KW to heat the one litre of water by +1*C in one minute, or 4.56KW to heat the one litre of water by +1*C in one second.
By passaging the CO2 through the +100*C water so the CO2 heats up from +30*C to +100*C in one second, the 9,000 bar for per litre per second is achieved.
What is not known is will the turbines produce the same conversion rates running on CO2 as they do on water.
However should they not be able to convert the 9,000 bar one litre per second to 720KW then the conversion method needs to use the open technology DaS Valve which 100% converts gas pressure to water pressure.
sarkeizen
I'm not really too concerned about the many detractors here, many of them come off like minions of the big energy companies who stand to lose there positions if anybody does actually come up with a true alternative energy source.
This almost deserves a topic in and of itself.  So do people really believe that there are people here who are paid by energy companies to post?  Seriously?
Vinyasi
Quote from: forest on November 29, 2014, 04:10:07 PM
Overunity is impossible , that's a fact . However this doesn't mean free energy is impossible, and it even doesn't mean free energy with amplification is impossible. You can test it yourself, but it's not recommended.... for example solar panel can be have rised power output if you use a lens to focus more sun rays on it.
And Joseph Newman's device got a kick in the pants, so to speak, when Byron Brubaker advised him to replace his rotary permanent magnets with plastic canisters of helium wrapped with an open coil to take advantage of the voltage doubling occurring within Newman's humungous coil. The open coil transferred the electrostatic field of Newman's massive coil into the helium gas. This excited this noble gas and caused it to emit a very high frequency -- much higher than the low frequency of the rotating canisters.
This higher frequency blended with the lower frequency. The result was a quickening of electrical reactance sufficient enough to reverse current and return it to its source, his dry cell batteries, with an amperage of a few hundred milliamperes. Yet, it was the humungous torque provided by the massive coil which was the true overunity of his device since it could easily rotate a sump pump and, against the inertial friction of the water, pump massive gallons per minute with the added advantage of never depleting his battery source! Unfortunately, he did wear them out since they were not designed to be recharged. So, Byron suggested to Newman to replace those dry cell batteries with a solar panel, but Newman refused to take Byron's advice. Oh, well ...
Please see ...
https://www.quora.com/Has-anyone-tried-to-recreate-Joseph-Newmans-perpetual-motion-machine/answer/Vin-Yasi
and ...
Vinyasi
Quote from: Nink on December 04, 2014, 09:57:22 PM
The bases of overunity is 1+1=3   I can prove this is incorrect.  If anyone believes the whole is greater than the sum of the parts they are sadly mistaken.
Consider the following example in which the whole is less than the absolute value of one of its parts ...
https://en.wikiversity.org/wiki/Free_Energy_does_not_Exist#Anomalous_Kirchhoff_Behavior
