POST YOUR TESLA BASED THEORIES ON ENERGY GENERATION
Started by gemstone hell, December 09, 2014, 02:44:20 AM
uep57
I've posted in this group the theory is the basis for the Tesla's waveguide get free energy from the vacuum because that waveguide is a negative resistor.
http://overunity.com/16399/teslas-transmission-waveguide-equations/new/#new
regards
UEP57
Fray Mamerto Esquiú
thx1138
Quote from: sparks on December 09, 2014, 05:31:41 AM
The induced voltage travels up the transformer and reaches the terminal faster than the current can flow through the wire which forms the secondary.  This appears as faster than the speed of light electricity but in reality the power is going up the tower length not through the wire itself.
  This can't happen at low frequency.  The current needs to flow only in the close coupled turns for the length of these turns.  So the frequency of the primary input is matched to the length of the secondary turn.   RF current flows in the first turns and then up the secondary as described above.
I've been wondering what the effect of the bold text in the following quote from the Tesla transmission patent is:
"The coil B [extra coil] is wound on a frame or drum D' of insulating material, with its turns close together. I have discovered that when so wound the effect of the small radius of curvature of the wire itself is overcome and the coil behaves as a conductor of large radius of curvature, corresponding to that of the drum. This feature is of considerable practical importance and is applicable not only in this special instance, but generally."
https://teslauniverse.com/nikola-tesla/patents/us-patent-1119732-apparatus-transmitting-electrical-energy
In the patent, coil C is the primary, A is the secondary, and B is the "extra" coil wound around "drum..of insulating material" D'.
If I understand your post correctly, it means the purpose of the extra coil wound around a cylinder of insulating material is to decouple, if you will, the voltage from the current. Is that correct? Can you expound on that a bit please?
darediamond
Quote from: Doug1 on December 09, 2014, 07:05:33 AM
I concur with Sparks. I think most will not understand what he stated though. my experience has been with 4 volts dc from a dead 12 volt battery I was able to get up to 250 volts ac. In theory any voltage being positive and a modest amperage you can get what ever output you want if you have enough materials to build it.
  The law of induction states it very well.maybe too well. Tesla coil for electromagnets is pretty strait forward but seldom comprehended. Think like a child when reading patents "ask why" a lot. Be open to learning and less concerned with just copying. Without understanding the "why" there is no understanding the how to.
You nailed Dough by your words towards the end of your comment. "think like a child when reading patents" ask why" a lot. BE OPEN TO LEARNING AND L E S S COPYING"!!!!!
WAO WHAT AN EYE OPENER!!
