Delayed Lenz or not?... post your explaination!
Started by gotoluc, December 16, 2014, 07:22:08 PM
dieter
Good work, Luc. What really sucks here is that there is still no ignore-user function in this Forum, which reminds me of why I kept away for several months. You wouldn't want JP Morgan flooding your screen would you?
gotoluc
Quote from: MileHigh on December 21, 2014, 10:32:23 PM
Luc:
You saw an increased power draw when the generator coil is loaded.  Before you were insisting that there was no increased power draw.  You should try to account for your past errors and try to square them away with your readers.
The test was using a 25 Ohm load. Show me the post where I wrote a 25 Ohm load will have no increased in power draw.
Also, I was testing this with half the RPM and power input then the first test but it's clear to me now that you are not here to help a researcher as you have once again taken the first opportunity to try to discredit me and that I don't know what I'm doing.
You will not be able to support your written statement above and I'm no longer going to bother replying to your posts.
Best to move along now
Luc
synchro1
MarkE
Quote from: synchro1 on December 21, 2014, 11:26:18 PM
That only Works if the generator output is less then the input.
Can you show a case where the generator output is equal to or greater than the input?
Quote from: dieter on December 21, 2014, 11:29:08 PM
What really REALLY sucks here is that people don't do their own homework, and keep posting falsehoods because of it.
Select "Profile" from the menu just below the "OverUnity" banner head at top left.
Select "Account Settings", then under "Modify Profile" select "Buddies/Ignore List", then "Edit Ignore List" and enter in the alias of the poster whose posts you don't want to see.
