Thanks to ALL for your help!!
Motionless generator
Started by life is illusion, December 20, 2014, 01:17:45 PM
life is illusion
Hello everyone  :)
Here I show how to modify the motionless generator (Flynn concept) which was patented by Tom Bearden ( Patent number: US6362718B1). This modification will help this generator to go around Lenz's law and generate much higher power output. I hope you enjoy the vid. Please let me know what you think.
https://www.youtube.com/watch?v=kU_sylOTOFg&list=UUXEFFysykQp53qAVElhrAgg
FatBird
We here on Overunity have seen HUNDREDS of design "THEORIES" & "EQUATIONS" through the years that DON'T work.
Go ahead & build it, THEN post the results so we can see if it works or not.
If it works we will thank you & PRAISE you to the sky.
life is illusion
Hey fatbird :)
So much anger ;) I'm not here to be admired or praised, just simply sharing and trying to learn :)
I started to post in here 3 days ago and I already see so much negativity and anger. Whats up in here? How many of "people" in here are normal people who try to learn and how many are the agents? ;) :D
Madeo
Hi Life,
Thanks for posting your stuff. I've been  lurking in the forums for years, but it's only the past few months that i started posting in here and the resistance you encounter is something to be expected nowadays. You should browse the "News" section here and you'll see what I mean.
Anyways, I had experimented with Flynn concept couple years ago and it didn't work. The reason is LENZ law. Whenever I did try to switch the magnetic path to the other side  (using flip/flop system),  the CEMF prevents it from actually switching magnetic paths.
For a solid state system,  I think Flynn is not gonna be an easy thing to solve. The only way that I could think of to address this is to have a switching mechanism that turns on and fully turn off  (collecting BEMF in the process)  and then have the field switch to the other path.  Unfortunately, it required a more sophisticated electronics than i was willing to invest something like a microprocessor.
Cheers :)
life is illusion
Hello Madeo :)
Thank you for commenting :) I totally understand what you mean, but the bypass that I have installed in this design in parallel with the pick up coil might solve this problem. When you are taking the N pole of magnet away, the upper part of solenoid will generate S pole which will try to suck the N pole back, but at the same time, the other side of coil will generate N pole which through the bypass will attract the generated S pole on the upper side of solenoid. We should also keep in mind that we have driver coils installed on the line to suck back the N pole. In case if this didn't work, I guess we can locate a diode on the solenoid which will only pick up the electricity generated by incoming N pole and when N pole is leaving, it keeps the coil open and no current will flow, thus no magnetic field will be generated to stop the N pole to move away :)
And about the resistance; Don't worry my friend, I am the real resistance, these guys are either idiots or payed agents trying to stop the positive change :D
Best Regards
Sam
