Lenz free generator
Started by life is illusion, December 21, 2014, 03:20:03 PM
tinman
76 metric tons
574KPH
Kinetic energy value=965517680 joules  :D
https://www.youtube.com/watch?v=sE4A0nPjyqQ
tinman
Well since it seems that there is only to be rubbish posted here on this thread,here is some more.
See how poor old Petey struggles to explain his own solenoid motor,and gets it drastically wrong.
Another bathroom heater on display by the Macrame Army
The resistance of the coil stays the same--LOL
These guys really need to learn about changing coil inductance.
https://www.youtube.com/watch?v=4cGg0NK4mjU
Brad
i_ron
Quote from: Erfinder on September 17, 2016, 03:03:14 AM
The sad thing is you actually listen to the resident Lenz Law guru wannabe.  Sad, but your choice, and sir, I do not stand in your way.  The device you have constructed is one of the nicest out there, and I am referring to your Teal machine, I have no comment on the device depicted above.  Copy paste junky is a lost cause, not your problem, had he done his homework on Mr. Ward, he would have suggested a much simpler build, one in which LOW INDUCTANCE LOW RESISTANCE coils were used.
https://www.youtube.com/watch?v=NiEMKic_jx4
I show the exact same effect using low inductance low resistance coils operating at low frequency, using coils which have cores, but no common magnetic circuit between them, and advance from here showing the same effect in an air core system.......continue to listen to chris, he is going to lead you to exactly what you don't want.  You demonstrated what you are capable of, I gave you a silent standing applaud when you brought out your Teal replication.  You want a real generator, copy paste junky doesn't know how to build one.  You will understand what I'm saying when that design you are working on as per his suggestion fails.
Thanks for your comment on my Teal build, I am in shock!
I had seen the "take down" vid but as with most things I didn't have and couldn't find locally any decent sized laminations.
As our dish washer had bit the dust the motor laminations became the basic start for the core. Then an old ballast transformer for $10 from the recycle bandits gave me the long top and bottom pieces.
Working with laminations can be awkward at times, they must be clamped tightly but even at that, machining raises little burrs, the secret is to then grind a few thousands out to get rid of these "shorts" as H would call them.
Here my trusty old Black and Decker router is being pressed into service as a tool post grinder...
Ron
i_ron
Quote from: EMJunkie on September 17, 2016, 12:43:25 AM
Very Nice Ron!!!
Lots of turns on your Coil, like the shaded Pole Motor, and the MMF will be High, this the Magnetic Field. Start with one Coil at a time, then try 2 later on.
I learnt a lot from my build, no where near as good as yours!!!
   Chris Sykes
       hyiq.org
Thanks Chris! We will see how it performs yet, eh? These things, so simple, do take time to construct.
In discussing the concept with Gyula, I had asked him what he thought of laminations, low speed and heavy gauge wire for the coils... so this is what I am working towards as a first build.  But today is shot for projects as we are off up island for my bro-in-law's birthday and Sunday is my day of rest, soooo, next week I can start the coils...
Ron
