Lenz free generator
Started by life is illusion, December 21, 2014, 03:20:03 PM
0 Members and 68 Guests are viewing this topic.
shylo
Hi Ron , I didn't pay much attention to your ward generator, I 'm on limited data.
What one shall we do next?
Ron
The reason is, I don't like cores in my coils.
It's fine to use steel to concentrate the magnetic field of a PM rotor but, using it to intensify the field in a coil is a waste IMHO.
The reason I say this is ,from what I've seen is that increase in output is offset by the required increase in input or the increase in motoring ability is offset by the drag .
Something along the lines of core-less coils for motoring and generating at the same time,would be interesting.
Thanks artv
Quote from: shylo on September 25, 2016, 03:55:16 AM
Ron
Thanks artv
Under permanent energy load or under moderated pulse periods ?
rotor/stator: pm/pm pm/em em/pm em-pm/pm ...em-pm/em-pm  magnetic force source : pm=permanent magnet em=electromagnet
You think that air-core coils equipped machines does have a better effficiency ,caused by actio-reactio time ,or why ?
Is the field force intensifying solid core reacting as same when instead cooper coils this will be encored by cooper-alu or only aluminium coils ? Aluminium: eddy currents ! Non ferrit machine,but by magnetic force acting ? http://rexresearch.com/mrmagnet/mrmagnet.htm
shylo
Hi lanca, I only motor the coils once per revolution, mimicking Mr hand.
artv
Quote from: shylo on September 25, 2016, 04:34:15 AM
artv
A really ashamed  :-[  question,could you descript for me the programming of this "operation=act" ? I only know about "winding coils" !
Are you revoluting your motor by hand,handykraft,mechanical device,not an e-motor more a kinetical/mechanical transmissor /transmitter ?
Thank you for a more imaginable answer ! :)
With my kindest regard and a fine Sunday (with/-out family,in peace ::) )
        OCWL
Quote from: Erfinder on September 25, 2016, 05:19:57 AM
That is exactly what one should have!
And by a common shaft ? Motor=generator ? the dynamo principle ! ( 8)  Each one becomes MrDynamo or MrsDynamo, core-and coil-less)
                                                               :)   That is exactly what one should be !  :)
                                                            Decelerating the modern society life velocity
